machine work, k24 hotside
varia
Post by varia »
looking for somebody who can machine a k24 hotside housing to accept the volvo turbo.
Please pm if you somebody other then Hank
(I asked him, no answer yet probably he is very busy)
Thank you!
Chris
¯\_(ツ)_/¯
project 2226
Re: machine work, k24 hotside
Send Elaw a PM. He had Hank machine one, but is using a Porsche housing I sent him.
Didn't Jared do this as well?
And Dave?
There's gotta be a file for this floating around somewhere...
Jarid was running the Porsche housing.
scubadave
Post by scubadave »
PRY4SNO wrote:Didn't Jared do this as well?
And Dave?
I first did this. All i got was frustrated as I just don't think its capable of flowing the right volume. Hank had started cutting k24 hot sides to build hybrid RS2 turbos. I don't know how this worked out. I feel I constantly had dett from back pressure due to that housing. IMHO you're better off sourcing the Porsche hot side, but that's my 2c.
varia
Post by varia »
I got a hot side that was once machined by Hank. Now my machine shop guy able to copy it.
Actually, i will picking them up tomorrow.
I have a k26/6 hot side as well, but this one is a quicker spool so for now, i will test it.
¯\_(ツ)_/¯
project 2226
scubadave
Post by scubadave »
The Audi k26 hotside wont work with the volvo turbine. I gave up my volvo turbo because it pussed out too soon up high. If hank has been able to do a billet wheel for it and give it more life up top, thats awesome. I went with his billet k26 and im much more happy with the results. Its slower spool, but there's always a compromise. 33psi on e85 was worth the later spool.
GTJeff
Post by GTJeff »
Allot of material needed to be removed by hand after boring that Audi exhaust housing in order to create geometry similar to the Volvo exhaust housing. I used a small carbide burr on a Dremel to accomplish this.
ARD (http://www.ARDideas.com) has several billet wheels available for the Volvo K24 which might keep it from pussing out. One of them supposedly flows enough for 430 hp.
One thing that I have been wondering about is if a Porsche K24 compressor housing would fit since the Volvo compressor housing inlet sticks out about and inch and a half further than stock.
