paradox11235
Post by paradox11235 »
I've been seriously contemplating box flares on my 200, I might get in trouble since it's a 20v avant though...
Einbilden
Post by Einbilden »
audifreakjim wrote:Please do what I never did, and pull molds when you are done. Love where this is going.
Thanks , thats lots of work. But repair in case of mishap would be easier with molds. Maybe its time to learn fiberglass.
paradox11235 wrote:I've been seriously contemplating box flares on my 200, I might get in trouble since it's a 20v avant though...
Do it , i have seen B5 Avant with boxflairs and though it was square" ich" it locked very sexy.
Few updates
Right side sectioned and weldet
audi wide build 043.jpg (451.43 KiB) Viewed 55998 times
Overhead shoot
audi wide build 046.jpg (595.29 KiB) Viewed 55998 times
A little bit more hammering and some tweaks and i can start on the noses of the fenders. Once that is done the rear quaters will be next.
Then Rocker panels
Cheers
Mike
Einbilden
Post by Einbilden »
So i am working on the noses of the fender and i needed some targets for measurements , witch resulted in some parts removal.
The offending parts removed
audi wide build 074.jpg (864.97 KiB) Viewed 55936 times
Thing that are being modified so noses can get finished
audi wide build 077.jpg (708.34 KiB) Viewed 55936 times
Updates as soon as i get some more done .
Mike
scubagli
Post by scubagli »
Looks great, keep up the good work!
Einbilden
Post by Einbilden »
Thanks: Scubagli
Update.
Patch panel for fender
audi wide build 078.jpg (690.79 KiB) Viewed 55849 times
Other side but not tacked yet
audi wide build 080.jpg (501.75 KiB) Viewed 55849 times
More things i have learned doing this build:
Use New sheet metal , stripping the paint of used metal to make it weldable Eats Allot Of Time. :shame:
Cheers:
Mike
Einbilden
Post by Einbilden »
So work on the nose of the fenders is on Hold. The turn signals are just not stable enough to get the frame placed with any kind of
accuracy . I need eurolights to make that happen the way i want it to , as i only want to do this once . To top that off , i think i need to
redo the Headlight mounts to place the light further back . :bangshead: So i will focus on the rear of the car until i get some
one piece headlights .
This is how it sat tonight
ok 002.jpg (489.89 KiB) Viewed 55825 times
ok 003.jpg (410.49 KiB) Viewed 55825 times
ok 005.jpg (482.91 KiB) Viewed 55825 times
Thats it for now .
Mike
Einbilden
Post by Einbilden »
Made some progress on the Rear of the car.
Making a Hole
Rough fit Needs more love ,but starting to look like it was meant to be there
Mike
Einbilden
Post by Einbilden »
Looks like a radiator is going into the Trunk. Working on supplying air to make that happen. Any thoughts would be appreciated! :hail:
Has this been done before on a street car? If so where the results successful or failures?
An opening presents itself.
Needs more TLC but you get the idea.
Till next time.
Mike
WOMBAT
Post by WOMBAT »
I have nothing useful to add and I apologize for that, but I can't sit here and not commend your body work skills. This is so freakin' cool!
Do you have any wider wheels you can test fit? Can't wait to see that :)
Einbilden
Post by Einbilden »
Thanks Wombat.
audifreakjim: I am sorry I do not have wheels for a test fit and can not wait to see it myself also.
( Shuffling toward garage )
Mike
Not sure if the ET is correct but just sayin...
Yep, love those.
You should pick up a wheel and tire that you are thinking about running. Just to make sure your build is going to look and fit right. Although I can already tell your bodywork skills are way better than mine so I am sure it will be great either way :)
Derhare
Post by Derhare »
Please do 9x16 compomotives.
Einbilden
Post by Einbilden »
Thanks Mcstiff they have cool wheels and not that expensive.
audifreakjim Your Flares turned out super , I was gona copy those. ( and then the voices I my head started )Only difference is you cut into 5% of your car and I am cutting 70-80%.
Derhare Not shure on the wheel , But I was thinking 17x9 or 17x10.
Got some more done on the car
Shoot from rear
:wave:
Mike
Einbilden
Post by Einbilden »
More progress. Made more panels for the Radiator intake , pics to to follow.
Also fixed this
Holes welded and ground , waiting for rust destroyer
Also ordered this Front Bumper :hide:
audi bumper.jpg (70.54 KiB) Viewed 55390 times
Chiao
versacehobo
Post by versacehobo »
can't tell if you're serious about the bumper or not?
Einbilden
Post by Einbilden »
jaychen wrote:can't tell if you're serious about the bumper or not?
I like it that's why I ordered it. So yeah I am serious Kind Sir !
Comments are always Welcome ( Likes , Dislikes ) it all gets read and processed by my engineer. :twisted:
Derhare
Post by Derhare »
Waiting to see the final product before giving my .02 :thumbsup:
Can't wait to see the end product :beer:
Einbilden
Post by Einbilden »
themagellan wrote:Can't wait to see the end product :beer:
Thank you :thumbsup: :beer:
Got a couple of hours done on the car tonight.
Removed backseat center pivot mount
Also all the control units under the backseat are now gone
All this meant having to be in the car. Getting in and out a few times I realized just how Light these cars are in the Rear. :o Glad I am adding weight in the Trunk to hopefully offset that a bit.
:wave:
Einbilden
Post by Einbilden »
Received the bumper yesterday, and slid it under the car. Needs to get Wider, plus the top edge of the center opening would look better Straight (to me anyways). Maybe I get some time tomorrow to work on the car. Ill keep you guys posted.
Looks good man, keep putting in the hours and it will be ready for paint before you know it. Will be watching!
Toxcheap
Post by Toxcheap »
Einbilden wrote:Received the bumper yesterday, and slid it under the car. Needs to get Wider, plus the top edge of the center opening would look better Straight (to me anyways). Maybe I get some time tomorrow to work on the car. Ill keep you guys posted.
Damn what are the odds, that's the bumper I have for my black coupe.
Same vendor?
