V8 and 5000 Torsion rear diff
chopped
Post by chopped »
What is the Diff between these two diffs? :D
Berserker
Re: V8 and 5000 Torsion rear diff
Post by Berserker »
V8 is torsen, 5k is open/lockable
V8 is 4.11:1, 5kq is 4.11:1, 5ktq is 3.89:1
I'm sure there is more, but those are two differences off the top of my head
chopped
Post by chopped »
Awesome! So how about a v8 rear diff and a stock 4000 trans O1A I think they are. I know the gear set is the same but can the torsion rear diff work with the locker front?
the 4000 comes with an 016 transmission. You can run a locker front and torsen rear. I'd much rather run a torsen center and torsen rear.
To do that you'd need a transmission from a 200 20vt which is a 4.11 ratio 016 with a torsen center differential. Torsen center, torsen rear. And better highway gear ratios in the 200 20v transmission than the 4000.
Yeah.
AngryTaco
Post by AngryTaco »
v8q dif is also much stronger which is why it's desirable to high horsepower urS guys
varia
Post by varia »
AngryTaco wrote:v8q dif is also much stronger which is why it's desirable to high horsepower urS guys
im not sure about this
¯\_(ツ)_/¯
project 2226
alxdgr8
Post by alxdgr8 »
Pretty sure I've seen many more broken V8 diffs than anything else.
lolwat
youz trollin
AngryTaco
Post by AngryTaco »
why do I always see v8q difs going like mad for like $400 then?
The urS guys eat them up
Or am I wrong? Seriously correct my ignorance if I am
roortube
Post by roortube »
Moderate power delivery through and out of a turn is better with a torsen rear. High power launches break torsens. It depends on intended use.
Rob
AngryTaco
Post by AngryTaco »
ohhhhhh ok. That whats I thought honestly. I coulda swore I saw other people say it was stronger. *shrugs* Guess that means my v8q will destroy an urS in the corners right?
Lift a wheel during a turn with lotsa power and sticky tires and bye bye diff. They dont like power or shock.
They are a good match for the 20v crew ;)
AngryTaco
Post by AngryTaco »
ringbearer wrote:They are a good match for the 20v crew ;)
This is what I see
123quattro
Post by 123quattro »
What they said above. Put a V8q diff in something that can spin the tires and they explode. I wanted one for my 200 20v until I saw what Sam Stone did to his.
