Ronald G Wainwright+ wrote:[/quote]
Geez Marc, you know how to make a guys hart jump a beat or two. Even though it's not my motor anymore I still feel it an extended part of the familey. I started to feel faint but glad to have kept going & read that the motor was OK(you should add a Phew emoticon).
But let me see if I can understand. So the starter teeth were extending past the flywheel teeth & binding obviousley on the top of the flywheel & couldn't return cause of the binding?[/quote]
Yep
?, if you make up a spacer for the starter will you need longer starter bolts?
& why did this happen?
the starter bolts I'm using are already long enough, no biggie there. I only need about a 1/4 spacer (which will put the starter fairly close to the oil filter, but not touching.
Had an impulse buy on an FMIC tonight, I really liked the design, vertical flow, dual in single out configuration:
cuatrokoop
Post by cuatrokoop »
Heh....So are you even going to bother with running it N/A or just go for broke now?
House, what house? :-D
cuatrokoop wrote:Heh....So are you even going to bother with running it N/A or just go for broke now?
Nope, Its Turbo Time! Pulling the heads when I suspected valve damage sealed the deal.
a whole different kind of 'going for broke' :(
WAUG0806
Post by WAUG0806 »
I understand your logic completely... :P
cuatrokoop
a4kquattro wrote:Nope, Its Turbo Time! Pulling the heads when I suspected valve damage sealed the deal.
That's what I figured.
Yous ain't kiddin'...
Derracuda
Post by Derracuda »
a4kquattro wrote:Had an impulse buy on an FMIC tonight, I really liked the design, vertical flow, dual in single out configuration:
good luck fitting that in there with your radiator and fan marc :) i looked at that same IC the other night on ebay.
Ah, you're forgetting my front bumper setup ;)
Plenty of room down der...
yodasfro
Post by yodasfro »
Did put the heads back on already?
yodasfro wrote:Did put the heads back on already?
nah, thats an old picture, gotta get some parts first (head gaskets, studs, etc).
birdmanmt
Post by birdmanmt »
wow, that's a lotta work! I think turbo's are a good idea! :-)
audibeans
Post by audibeans »
birdmanmt wrote:wow, that's a lotta work! I think turbo's are a good idea! :-)
LOL, I dont where some these guys get there energy....
noriceforyou
Post by noriceforyou »
I remember hearing a commercial about some pill that can make you go up to four hours at a crack.......
Derracuda
Post by Derracuda »
jerk! :P
Alrighty, another weekends worth of progress. Thanks to Nate for getting me a set of extra headgaskets and other goodies real quick-like :woowoo:
I installed ARP 16v VW headstuds and stacked gaskets
Pulled the oil pan(s) and drilled/tapped for the turbo oil drains. Man, theres a lot of freakin bolts holding the pans up...
drivers side drain:
Passenger side drain:
I'm a little nervous about the passenger drain in the pan. Its really close to the oil level when full and I'm concerned about potential restriction in the drain line while cornering, etc. Apparently Nate hasn't had any problem with this(?)
oil supply line:
I also sealed off the nipple facing rearward on the drivers side valve cover to give more clearance for the master cylinder. The red powdercoat came out pretty good too:
Now I just need some manifolds and turbos :)
SEStone
Post by SEStone »
Damn, it's like they designed bosses for turbo feeds and drains!
Sam
Sam Stone
Toxcheap
Post by Toxcheap »
HOLY SHIT you really made some progress after I left GOOD JOB!!!!!!!!!!
WOMBAT
Post by WOMBAT »
ah, the signature marc red valve covers 8)
20v90q
Post by 20v90q »
Looks Great! Nice, clean install. Now when are you going to spray some degreaser on those heads/oil pans? :-)
Toxcheap wrote:HOLY SHIT you really made some progress after I left GOOD JOB!!!!!!!!!!
I was determined to get the engine bolted back up before I left. I didn't get outta there until almost 10:30! Sorry I didn't stop by last night, YGM.
birdmanmt
Post by birdmanmt »
Looks great! Are those just NPT-->AN adapters?
birdmanmt wrote:Looks great! Are those just NPT-->AN adapters?
yep, 1/2" NPT to -10AN
3bAudios
Post by 3bAudios »
holy crap man, that motor was on the floor still when i left. if i had known you were going to be bolting it up i would have stuck around!!! looks great man
yodasfro
Post by yodasfro »
Good stuff Marc keep it up :thumbsup: 8)
Derracuda
Post by Derracuda »
i'm planning on sticking the drain in the boss above where you put yours in, in the block instead of the pan.
looks great though marc!
