But let me see if I can understand. So the starter teeth were extending past the flywheel teeth & binding obviousley on the top of the flywheel & couldn't return cause of the binding?[/quote]
Yep
?, if you make up a spacer for the starter will you need longer starter bolts?
& why did this happen?
the starter bolts I'm using are already long enough, no biggie there. I only need about a 1/4 spacer (which will put the starter fairly close to the oil filter, but not touching.
i looked at that same IC the other night on ebay.
8)
