Everything will be available. I'm currently driving it and won't break it until the engine and trans are spoken for as I will need a replacement for the wife/family car. I'm looking for a clean 04-05 A4 1.8T wagon with a 6 speed which is proving rather difficult.
Email me at chaloux at gmail dawt com or PM me, I can text/call as well if you'd rather
Big items:
$2500- 260km - 2.5L AEL TDI engine with mounts/wiring harness/hoses/chipped ECU/etc. COMPLETE! Use this for a swap or break it down and make a stroker, whatever. Should be re-sealed and gasketed in my opinion but throw it in and run it if you want. Timing belts done ~15000km ago
$1500 - 6 speed TDI 01E - CYT code (as far as I can find the same as a DQT). Cruise at 2000rpm @ 65mph. Will need output flanges but I can provide those for $50. Also have the rear diff in good shape with the same KM
$150 - S6 wheel
$100 - S6+ 6 speed shift knob. This is round and feels awesome in your hand.
It obviously has all the cool euro bits - a storage compartment under the steering wheel, factory spacer in between the switches/buttons, square pattern door cards and manual (lightweight!) seats. Euro front and rear bumpers (A6, NOT wider S6). Body panels are all pretty rusty and not worth anything. Black roof rails, big dong of a hitch. Leveling headlights of which the driver's side doesn't work (but I have the switch and wiring). Euro rear plate surround and euro lights (one of which is cracked). I'll have to work on pricing of this stuff with pictures as none of it is quite "perfect"
