Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Zaworek
Post by Zaworek »
Hello fellow Audi owners
Let me introduce my project i have been working on for the past 2 years or so.
Beforehand I would like to Thank to all the people/friends who were part of this project for their support.
I took some photos along the progress and will start with the current photos and description and work backwards
Here are some details and i will try to upload photos of the build in the same order.
Body
- 1991 Audi Coupe Quattro
- B4 hood and rs2 head lights - HID's low / high beam and fog lights
- Audi S2 front and rear bumpers
- Welded and braced front and rear strut towers
- Fully restored under chassis
- Aerocatch hood fasteners
Engine menagement
- Vems + EFI Express custom wire harness + tune by Marc
- Battery relocation kit
- Flex fuel e85 sensor + gauge
- anti lag
Engine
- 3b motor
- Stock pistons
- Scat rods,
- Coated bearings
- Brass distributor gear upgrade
- Phenolic spacer
- GT 3071r turbo anti-surge inlet, 3" V-Band outlet
- Fully rebuild head
- Individual coils conversion
- Replaced all coolant hoses
- Fully rebuild head with new valves (Intake / exhaust), new guides, lifters
- ARP Studs
- No AC
- all gaskets, seals replaced
- hardened timing belt cog gear
- timing belt kit , tensioner, water pump
- some carbon fiber dressing along with red wrinkle powder coated valve cover, thermostat housing and water manifold.
Fuel delivery
- EFI Express fuel rail -6an
- 1200cc injectors
- Aeromotive fuel pressure regulator
- ss braided fuel lines
- Steel hard lines front to back under chassis
- Refreshed fuel tank
- 93oct /e85
- Fuel tank plastic hose delete
- upgraded fuel pump
- Intake
- s2 intake manifold
- Tial 50 BO
- s2 IC
- Silicone hoses
Exhaust
- Wagner Sport exhaust manifold
- Hanks downpipe 3 inch
- 3b wastegate
- 3" all the way with 3" rear magna flow muffler
- V-band connections
Interior
- All upper trim A B C pilars and head liner in black suede
- s2 black leather trim
- b4 manual heating unit also blacked out trim
- led lights
- s2 steering wheel
- s4 b5 shifter knob
Power steering
- Stock Audi b4 90 power steering pump
- Custom pressure hoses
- rebuild rack and pinion
Transmission
- 01e 6 speed
- Stage 4 + clutch 6 puck
- Audi s4 b5 modified shifter linkage
- Rebuild rear diff
- Rebuild Audi 4k prop shaft
- Rebuild axles
- EFI Express tranny brackets
Suspension
- Solid aluminium subframe bushings
- Bilsteins HD shocks
- H&R springs
- Solid spherical bearing strut mounts
- Restored full suspension
- 5 lug swap
- Wheel studs
- Seem welded rear control arms and repainted
Brakes
- Vacuum assisted servo B4
- Full ABS unit deleted
- replaced hard brake lines
Front
- Porsche Boxter S calipers 4 piston
- Audi a8 323mm x 30 rotors
- Custom brackets
- ss braided lines
Rear
- Porsche Boxter S rear Calipers 4 piston
- Audi s4 b7 rotors 300mm x 22
- Custom brackets
- ss braided lines
- Hydraulic e-brake conversion - modified stock handle to accommodate the hydraulic cylinder under stock center console
Wheels
- 17 inch wheels wrapped with 235/45/17 BF Goodrich comp 2
Sebastian's CQ91' winter .jpg (2.99 MiB) Viewed 42100 times
Sebastian's CQ91' road trip 4.JPG (2.54 MiB) Viewed 42100 times
Sebastian's CQ91' initial inspection .JPG (2.97 MiB) Viewed 42100 times
Sebastian's CQ91' project 1.JPG (3.58 MiB) Viewed 42100 times
Sebastian's CQ91' initial inspection 3.jpg (3.97 MiB) Viewed 42100 times
- Sebastian -
Zaworek
Re: Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Post by Zaworek »
bit more of the b4 look
Sebastian's CQ91' old garrage storage 1.JPG (3.36 MiB) Viewed 42095 times
Sebastian's CQ91' body panels.jpg (2.04 MiB) Viewed 42095 times
- Sebastian -
Zaworek
Post by Zaworek »
some engine bay prep work and strut tower fix and brace, battery relocation
Sebastian's CQ91' shot towers.jpg (2.57 MiB) Viewed 42094 times
Sebastian's CQ91' front tower fix 2.JPG (2.91 MiB) Viewed 42094 times
Sebastian's CQ91' front tower fix and strut bar mount.JPG (2.86 MiB) Viewed 42094 times
front tower strut brace mount.JPG (2.7 MiB) Viewed 42094 times
Sebastian's CQ91' engine paint prep.JPG (2.44 MiB) Viewed 42094 times
- Sebastian -
Zaworek
Post by Zaworek »
some color and steering
Sebastian's CQ91' engine bay paint 4.JPG (2.55 MiB) Viewed 42094 times
Sebastian's CQ91' engine bay paint .JPG (2.82 MiB) Viewed 42094 times
Sebastian's CQ91'engine bay finished paint .JPG (2.61 MiB) Viewed 42094 times
Sebastian's CQ91' power steering job.JPG (599.15 KiB) Viewed 42094 times
Sebastian's CQ91' engine paint finished.JPG (3.8 MiB) Viewed 42094 times
- Sebastian -
Zaworek
Post by Zaworek »
steering rack and fluid tanks installed with Vems harness and very slimmed down stock harness
Sebastian's CQ91' stock harness slimmed down.jpg (3.04 MiB) Viewed 42093 times
Sebastian's CQ91' vems harness EFI Express.JPG (2.25 MiB) Viewed 42093 times
Sebastian's CQ91' engine bay random shoot 2.JPG (2.58 MiB) Viewed 42093 times
Sebastian's CQ91' engine bay random shoot 1.jpg (2.85 MiB) Viewed 42093 times
- Sebastian -
Nice to see you found us over here! You need to post the flame thrower vids!
Zaworek
Post by Zaworek »
Thanks for the Welcome I will have them posted soon working on youtube channel and trying to finish this post also.
- Sebastian -
Zaworek
Post by Zaworek »
here is a bit of the under chassis and suspension work.
Sebastian's CQ91' front suspension assembly .jpg (2.84 MiB) Viewed 42057 times
Sebastian's CQ91' front suspension .JPG (2.12 MiB) Viewed 42057 times
Sebastian's CQ91' rear suspension assembly 1.jpg (3.06 MiB) Viewed 42057 times
Sebastian's CQ91' rear suspenssion shot.JPG (2.81 MiB) Viewed 42057 times
- Sebastian -
Zaworek
Post by Zaworek »
rear brakes
Sebastian's CQ91' caliper paint.JPG (2.35 MiB) Viewed 42046 times
Sebastian's CQ91' rebuild calipers.JPG (2.44 MiB) Viewed 42046 times
Sebastian's CQ91' rear brakes done 1.jpg (2 MiB) Viewed 42046 times
Sebastian's CQ91' rear brakes done.jpg (2.36 MiB) Viewed 42046 times
Sebastian's CQ91' rear brakes done 2.jpg (2.45 MiB) Viewed 42046 times
- Sebastian -
Zaworek
Post by Zaworek »
front brakes
Sebastian's CQ91' front brakes bracket .JPG (3.05 MiB) Viewed 42046 times
Sebastian's CQ91' brakes done.jpg (2.85 MiB) Viewed 42046 times
Sebastian's CQ91' front brakes .JPG (1.93 MiB) Viewed 42046 times
Sebastian's CQ91' wheels 17%22.jpg (2.98 MiB) Viewed 42046 times
- Sebastian -
Zaworek
Post by Zaworek »
some random photos
Sebastian's CQ91' rebuild calipers.JPG (2.44 MiB) Viewed 42036 times
Sebastian's CQ91' brake suspension shoot.jpg (2.84 MiB) Viewed 42036 times
Sebastian's CQ91' fuel filter housieng restored.JPG (2.31 MiB) Viewed 42036 times
- Sebastian -
Zaworek
Post by Zaworek »
fuel lines, fuel tank connection with -6an fitting
Sebastian's CQ91' fuel tank plastic hose fix.jpg (3.21 MiB) Viewed 42027 times
Sebastian's CQ91' fuel tank lines.JPG (2.94 MiB) Viewed 42027 times
Sebastian's CQ91' fuel filter new lines.JPG (2.31 MiB) Viewed 42027 times
- Sebastian -
Zaworek
Post by Zaworek »
fuel pump and some wiring
Sebastian's CQ91' fuel pump setup.JPG (2.3 MiB) Viewed 42026 times
Sebastian's CQ91' fuel pump setup 3.JPG (2.39 MiB) Viewed 42026 times
Sebastian's CQ91' fuel pump setup 2.jpg (2.3 MiB) Viewed 42026 times
- Sebastian -
Zaworek
Post by Zaworek »
Our old shop (Mine and Adams) with two of my coupes far left, Danny's coupe with the blue tape and black primed Adam's full S2 built coupe inside.
Sebastian's CQ91' old shop with coupes 2.JPG (2.62 MiB) Viewed 42025 times
- Sebastian -
Zaworek
Post by Zaworek »
the whole interior got stripped of old heavy sound proofing and carpet under mat.
Sebastian's CQ91' interior strip down 3.JPG (2.83 MiB) Viewed 42025 times
Sebastian's CQ91' interior prep 1.JPG (2.86 MiB) Viewed 42025 times
Sebastian's CQ91' interior strip 2.JPG (2.83 MiB) Viewed 42025 times
- Sebastian -
Zaworek
Post by Zaworek »
b4 manual climate control rebuild with new flapers and all black dash black leather trim also all old unused stock harness was cut out.
Sebastian's CQ91' manual box swap.jpg (2.15 MiB) Viewed 42024 times
Sebastian's CQ91' wiring 2.JPG (2.58 MiB) Viewed 42024 times
Sebastian's CQ91' dash .jpg (2.76 MiB) Viewed 42024 times
Sebastian's CQ91' interior black out.JPG (2.34 MiB) Viewed 42024 times
- Sebastian -
Zaworek
Post by Zaworek »
here is the upper trim of the interior that i have done in black suede it took two days to wrap it, my fiancee took snapped a picture of the material being applied
Sebastian's CQ91' suede hard labor.jpg (2.62 MiB) Viewed 42021 times
Sebastian's CQ91' suede complete uppper trim.JPG (2.65 MiB) Viewed 42021 times
Sebastian's CQ91' suede interior 2.JPG (1.95 MiB) Viewed 42021 times
Sebastian's CQ91' suede trunk.JPG (2.26 MiB) Viewed 42021 times
Sebastian's CQ91' suede headliner 1.JPG (2.62 MiB) Viewed 42021 times
- Sebastian -
Well done! Talk about a complete, and balanced build.
Also, did you get black euro trim or dye your OE stuff?
How hard was it to do, and how much material did you buy then have left over? Recommend a specific adhesive?
welcome!
Zaworek
Post by Zaworek »
Thank you Marc, i will post more photos and that great video we shot together at sfest and to pry4sno the seat belts covers o my coupe are painted black and the o shit handle were stripped a part and plastic dipped and they hold up pretty good. As to the material i have bought 3 yards of suede regular and also bought 3 yards of suede with foam backing and have some left overs. I will check what adhesive i have used and get back to you
- Sebastian -
Zaworek
Post by Zaworek »
visiting Marc at EFI Express to pick up the motor
Sebastian's CQ91' some carbon.jpg (3.09 MiB) Viewed 41930 times
Sebastian's CQ91' Engine pick up 1.jpg (2.74 MiB) Viewed 41930 times
Sebastian's CQ91' engine pick up 2.jpg (2.79 MiB) Viewed 41930 times
- Sebastian -
Zaworek
Post by Zaworek »
motor back at the garage and ready for further assembly along with 01e 6 speed from Dana here are some random shoots
the motor here is still with the rs2 exhaust manifold which was later upgraded to the Wagner Sport exhaust manifold.
Sebastian's CQ91' engine head valves.JPG (2.83 MiB) Viewed 41927 times
Sebastian's CQ91' engine carbon.jpg (2.86 MiB) Viewed 41927 times
Sebastian's CQ91' carbon parts 1.jpg (3.4 MiB) Viewed 41927 times
Sebastian's CQ91' 01e 6 speed.JPG (1.61 MiB) Viewed 41927 times
Sebastian's CQ91' motor and tranny stored.JPG (3.06 MiB) Viewed 41927 times
- Sebastian -
Zaworek
Post by Zaworek »
some red wrinkle powder coat with some carbon fiber trim
Sebastian's CQ91'engine random shoot 9.JPG (2.64 MiB) Viewed 41925 times
Sebastian's CQ91' engine random shoot 6.JPG (2.75 MiB) Viewed 41925 times
Sebastian's CQ91' engine carbon 2.jpg (2.44 MiB) Viewed 41925 times
- Sebastian -
Wow. You're not messing around. Nice build!!!
