Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Hello fellow Audi owners
Let me introduce my project i have been working on for the past 2 years or so.
Beforehand I would like to Thank to all the people/friends who were part of this project for their support.
I took some photos along the progress and will start with the current photos and description and work backwards
Here are some details and i will try to upload photos of the build in the same order.
Body
- 1991 Audi Coupe Quattro
- B4 hood and rs2 head lights - HID's low / high beam and fog lights
- Audi S2 front and rear bumpers
- Welded and braced front and rear strut towers
- Fully restored under chassis
- Aerocatch hood fasteners
Engine menagement
- Vems + EFI Express custom wire harness + tune by Marc
- Battery relocation kit
- Flex fuel e85 sensor + gauge
- anti lag
Engine
- 3b motor
- Stock pistons
- Scat rods,
- Coated bearings
- Brass distributor gear upgrade
- Phenolic spacer
- GT 3071r turbo anti-surge inlet, 3" V-Band outlet
- Fully rebuild head
- Individual coils conversion
- Replaced all coolant hoses
- Fully rebuild head with new valves (Intake / exhaust), new guides, lifters
- ARP Studs
- No AC
- all gaskets, seals replaced
- hardened timing belt cog gear
- timing belt kit , tensioner, water pump
- some carbon fiber dressing along with red wrinkle powder coated valve cover, thermostat housing and water manifold.
Fuel delivery
- EFI Express fuel rail -6an
- 1200cc injectors
- Aeromotive fuel pressure regulator
- ss braided fuel lines
- Steel hard lines front to back under chassis
- Refreshed fuel tank
- 93oct /e85
- Fuel tank plastic hose delete
- upgraded fuel pump
- Intake
- s2 intake manifold
- Tial 50 BO
- s2 IC
- Silicone hoses
Exhaust
- Wagner Sport exhaust manifold
- Hanks downpipe 3 inch
- 3b wastegate
- 3" all the way with 3" rear magna flow muffler
- V-band connections
Interior
- All upper trim A B C pilars and head liner in black suede
- s2 black leather trim
- b4 manual heating unit also blacked out trim
- led lights
- s2 steering wheel
- s4 b5 shifter knob
Power steering
- Stock Audi b4 90 power steering pump
- Custom pressure hoses
- rebuild rack and pinion
Transmission
- 01e 6 speed
- Stage 4 + clutch 6 puck
- Audi s4 b5 modified shifter linkage
- Rebuild rear diff
- Rebuild Audi 4k prop shaft
- Rebuild axles
- EFI Express tranny brackets
Suspension
- Solid aluminium subframe bushings
- Bilsteins HD shocks
- H&R springs
- Solid spherical bearing strut mounts
- Restored full suspension
- 5 lug swap
- Wheel studs
- Seem welded rear control arms and repainted
Brakes
- Vacuum assisted servo B4
- Full ABS unit deleted
- replaced hard brake lines
Front
- Porsche Boxter S calipers 4 piston
- Audi a8 323mm x 30 rotors
- Custom brackets
- ss braided lines
Rear
- Porsche Boxter S rear Calipers 4 piston
- Audi s4 b7 rotors 300mm x 22
- Custom brackets
- ss braided lines
- Hydraulic e-brake conversion - modified stock handle to accommodate the hydraulic cylinder under stock center console
Wheels
- 17 inch wheels wrapped with 235/45/17 BF Goodrich comp 2
Body
Engine menagement
- anti lag
Engine
- 3b motor
- Stock pistons
- Scat rods,
- Coated bearings
- Phenolic spacer
- ARP Studs
- No AC
Fuel delivery
- 1200cc injectors
- 93oct /e85
- Intake
- Tial 50 BO
- s2 IC
- Silicone hoses
Exhaust
- 3b wastegate
Interior
- led lights
- s2 steering wheel
Power steering
Transmission
- 01e 6 speed
- Rebuild rear diff
- Rebuild axles
Suspension
- H&R springs
- 5 lug swap
- Wheel studs
Brakes
Front
- Custom brackets
- ss braided lines
Rear
- Custom brackets
- ss braided lines
Wheels
- Sebastian's CQ91' winter .jpg (2.99 MiB) Viewed 42124 times
- Sebastian's CQ91' road trip 4.JPG (2.54 MiB) Viewed 42124 times
- Sebastian's CQ91' initial inspection .JPG (2.97 MiB) Viewed 42124 times
- Sebastian's CQ91' project 1.JPG (3.58 MiB) Viewed 42124 times
- Sebastian's CQ91' initial inspection 3.jpg (3.97 MiB) Viewed 42124 times
- Sebastian -
Re: Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
bit more of the b4 look
- Sebastian's CQ91' old garrage storage 1.JPG (3.36 MiB) Viewed 42119 times
- Sebastian's CQ91' body panels.jpg (2.04 MiB) Viewed 42119 times
- Sebastian -
some engine bay prep work and strut tower fix and brace, battery relocation
- Sebastian's CQ91' shot towers.jpg (2.57 MiB) Viewed 42118 times
- Sebastian's CQ91' front tower fix 2.JPG (2.91 MiB) Viewed 42118 times
- Sebastian's CQ91' front tower fix and strut bar mount.JPG (2.86 MiB) Viewed 42118 times
- front tower strut brace mount.JPG (2.7 MiB) Viewed 42118 times
- Sebastian's CQ91' engine paint prep.JPG (2.44 MiB) Viewed 42118 times
- Sebastian -
some color and steering
- Sebastian's CQ91' engine bay paint 4.JPG (2.55 MiB) Viewed 42118 times
- Sebastian's CQ91' engine bay paint .JPG (2.82 MiB) Viewed 42118 times
- Sebastian's CQ91'engine bay finished paint .JPG (2.61 MiB) Viewed 42118 times
- Sebastian's CQ91' power steering job.JPG (599.15 KiB) Viewed 42118 times
- Sebastian's CQ91' engine paint finished.JPG (3.8 MiB) Viewed 42118 times
- Sebastian -
steering rack and fluid tanks installed with Vems harness and very slimmed down stock harness
- Sebastian's CQ91' stock harness slimmed down.jpg (3.04 MiB) Viewed 42117 times
- Sebastian's CQ91' vems harness EFI Express.JPG (2.25 MiB) Viewed 42117 times
- Sebastian's CQ91' engine bay random shoot 2.JPG (2.58 MiB) Viewed 42117 times
- Sebastian's CQ91' engine bay random shoot 1.jpg (2.85 MiB) Viewed 42117 times
- Sebastian -
Nice to see you found us over here! You need to post the flame thrower vids!
Thanks for the Welcome I will have them posted soon working on youtube channel and trying to finish this post also.
- Sebastian -
here is a bit of the under chassis and suspension work.
- Sebastian's CQ91' front suspension assembly .jpg (2.84 MiB) Viewed 42081 times
- IMG_2210.JPG (2.05 MiB) Viewed 42081 times
- Sebastian's CQ91' front suspension .JPG (2.12 MiB) Viewed 42081 times
- Sebastian's CQ91' rear suspension assembly 1.jpg (3.06 MiB) Viewed 42081 times
- Sebastian's CQ91' rear suspenssion shot.JPG (2.81 MiB) Viewed 42081 times
- Sebastian -
rear brakes
- Sebastian's CQ91' caliper paint.JPG (2.35 MiB) Viewed 42070 times
- Sebastian's CQ91' rebuild calipers.JPG (2.44 MiB) Viewed 42070 times
- Sebastian's CQ91' rear brakes done 1.jpg (2 MiB) Viewed 42070 times
- Sebastian's CQ91' rear brakes done.jpg (2.36 MiB) Viewed 42070 times
- Sebastian's CQ91' rear brakes done 2.jpg (2.45 MiB) Viewed 42070 times
- Sebastian -
front brakes
- Sebastian's CQ91' front brakes bracket .JPG (3.05 MiB) Viewed 42070 times
- Sebastian's CQ91' brakes done.jpg (2.85 MiB) Viewed 42070 times
- Sebastian's CQ91' front brakes .JPG (1.93 MiB) Viewed 42070 times
- Sebastian's CQ91' wheels 17%22.jpg (2.98 MiB) Viewed 42070 times
- Sebastian -
some random photos
- Sebastian's CQ91' rebuild calipers.JPG (2.44 MiB) Viewed 42060 times
- Sebastian's CQ91' brake suspension shoot.jpg (2.84 MiB) Viewed 42060 times
- Sebastian's CQ91' fuel filter housieng restored.JPG (2.31 MiB) Viewed 42060 times
- Sebastian -
fuel lines, fuel tank connection with -6an fitting
- IMG_4209.jpg (2.15 MiB) Viewed 42051 times
- IMG_6083.jpg (3.69 MiB) Viewed 42051 times
- Sebastian's CQ91' fuel tank plastic hose fix.jpg (3.21 MiB) Viewed 42051 times
- Sebastian's CQ91' fuel tank lines.JPG (2.94 MiB) Viewed 42051 times
- Sebastian's CQ91' fuel filter new lines.JPG (2.31 MiB) Viewed 42051 times
- Sebastian -
fuel pump and some wiring
- Sebastian's CQ91' fuel pump setup.JPG (2.3 MiB) Viewed 42050 times
- Sebastian's CQ91' fuel pump setup 3.JPG (2.39 MiB) Viewed 42050 times
- Sebastian's CQ91' fuel pump setup 2.jpg (2.3 MiB) Viewed 42050 times
- IMG_6877.jpg (2.39 MiB) Viewed 42050 times
- Sebastian -
Our old shop (Mine and Adams) with two of my coupes far left, Danny's coupe with the blue tape and black primed Adam's full S2 built coupe inside.
- Sebastian's CQ91' old shop with coupes 2.JPG (2.62 MiB) Viewed 42049 times
- Sebastian -
the whole interior got stripped of old heavy sound proofing and carpet under mat.
- Sebastian's CQ91' interior strip down 3.JPG (2.83 MiB) Viewed 42049 times
- Sebastian's CQ91' interior prep 1.JPG (2.86 MiB) Viewed 42049 times
- Sebastian's CQ91' interior strip 2.JPG (2.83 MiB) Viewed 42049 times
- Sebastian -
b4 manual climate control rebuild with new flapers and all black dash black leather trim also all old unused stock harness was cut out.
- IMG_7139.JPG (2.4 MiB) Viewed 42048 times
- Sebastian's CQ91' manual box swap.jpg (2.15 MiB) Viewed 42048 times
- Sebastian's CQ91' wiring 2.JPG (2.58 MiB) Viewed 42048 times
- Sebastian's CQ91' dash .jpg (2.76 MiB) Viewed 42048 times
- Sebastian's CQ91' interior black out.JPG (2.34 MiB) Viewed 42048 times
- Sebastian -
here is the upper trim of the interior that i have done in black suede it took two days to wrap it, my fiancee took snapped a picture of the material being applied
- Sebastian's CQ91' suede hard labor.jpg (2.62 MiB) Viewed 42045 times
- Sebastian's CQ91' suede complete uppper trim.JPG (2.65 MiB) Viewed 42045 times
- Sebastian's CQ91' suede interior 2.JPG (1.95 MiB) Viewed 42045 times
- Sebastian's CQ91' suede trunk.JPG (2.26 MiB) Viewed 42045 times
- Sebastian's CQ91' suede headliner 1.JPG (2.62 MiB) Viewed 42045 times
- Sebastian -
Well done! Talk about a complete, and balanced build.
Also, did you get black euro trim or dye your OE stuff?
How hard was it to do, and how much material did you buy then have left over? Recommend a specific adhesive?
welcome!
Thank you Marc, i will post more photos and that great video we shot together at sfest and to pry4sno the seat belts covers o my coupe are painted black and the o shit handle were stripped a part and plastic dipped and they hold up pretty good. As to the material i have bought 3 yards of suede regular and also bought 3 yards of suede with foam backing and have some left overs. I will check what adhesive i have used and get back to you
- Sebastian -
visiting Marc at EFI Express to pick up the motor
- Sebastian's CQ91' some carbon.jpg (3.09 MiB) Viewed 41954 times
- Sebastian's CQ91' Engine pick up 1.jpg (2.74 MiB) Viewed 41954 times
- Sebastian's CQ91' engine pick up 2.jpg (2.79 MiB) Viewed 41954 times
- Sebastian -
motor back at the garage and ready for further assembly along with 01e 6 speed from Dana here are some random shoots
the motor here is still with the rs2 exhaust manifold which was later upgraded to the Wagner Sport exhaust manifold.
- Sebastian's CQ91' engine head valves.JPG (2.83 MiB) Viewed 41951 times
- Sebastian's CQ91' engine carbon.jpg (2.86 MiB) Viewed 41951 times
- Sebastian's CQ91' carbon parts 1.jpg (3.4 MiB) Viewed 41951 times
- Sebastian's CQ91' 01e 6 speed.JPG (1.61 MiB) Viewed 41951 times
- Sebastian's CQ91' motor and tranny stored.JPG (3.06 MiB) Viewed 41951 times
- Sebastian -
some red wrinkle powder coat with some carbon fiber trim
- Sebastian's CQ91'engine random shoot 9.JPG (2.64 MiB) Viewed 41949 times
- Sebastian's CQ91' engine random shoot 6.JPG (2.75 MiB) Viewed 41949 times
- Sebastian's CQ91' engine carbon 2.jpg (2.44 MiB) Viewed 41949 times
- Sebastian -
Wow. You're not messing around. Nice build!!!
