1986 Coupe GT: Fresh Exhaust
the german
Re: 1986 Coupe GT: Fresh Exhaust
Post by the german »
Nice! So jealous of the lift!
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
scubagli
Post by scubagli »
Pretty awesome.
You can store crap under the car too ;)
I really want a lift!
w00t!
When's the 07k/t/quattro swap going to happen?
alxdgr8
Post by alxdgr8 »
PRY4SNO wrote:w00t!
I'm already looking for a 5spd 1.8t fwd passat parts car... TDI would be awesome but too much money
the german
97-99 passat or 98-99 A4 will get you the right engine (AEB)
I found a ton of info here when I was researching it: http://myweb.whitman.syr.edu/srotblat/swap/
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
alxdgr8
Post by alxdgr8 »
Well new fuel pump didn't fix the problem, time to dig deeper!
the german
Damn!
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
alxdgr8
Post by alxdgr8 »
the german wrote:Damn!
Yeah, going to triple check for vacuum leaks. Going to figure out what injectors it has too (fine or coarse thread), and probably order up a new set. Then I guess I need to check the setup of the fuel distro/metering plate.
the german
Have you tried that extra set of injectors I pulled from the wrecking yard? They were in a plastic bag in the trunk
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
alxdgr8
Post by alxdgr8 »
the german wrote:Have you tried that extra set of injectors I pulled from the wrecking yard? They were in a plastic bag in the trunk
Forgot about those, I'll give them a shot
alxdgr8
Post by alxdgr8 »
Got a Bentley this morning, going to dig into troubleshooting more tonight.
In other news, I'm picking up a complete 7A swap from Chris (varia). Not as potent as the 1.8T swap, but much easier and a better soundtrack. Then there's always the possibility of a 7At in the future if I decide 160hp isn't enough for 1 wheel drive.
the german
woohoo!! I like that solution :)
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
Classy!
ITBs down the road would make it sing.
