Jakes '91 200 Avant
20VAvant
Re: Jakes '91 200 Avant
Post by 20VAvant »
Midnight wrote:How wide of a wheel/tire can I run before I run into issues?
I currently run 18"x9.5" ET20mm with an 235/40-18 all around and haven't had any issues, it is pretty tight up front though..
-2014 Lexus IS350 - SOLD
-2015 Yamaha FZ-07 - SOLD
-2005 Honda CRF230F - SOLD
Midnight
Post by Midnight »
20VAvant wrote:I currently run 18"x9.5" ET20mm with an 235/40-18 all around and haven't had any issues, it is pretty tight up front though..
Are you running stock suspension?
Jake
The Stable:
1999 Saab 9-3 5-door
2002 Saab 9-3 SE 5-door
Midnight
Re: Jakes '91 200 Avant: Dash soldering confusion
Post by Midnight »
Opened up the dash to re-solder the connectors today. It looks like someone has done some work on them before. And some of the pins on the 26-pin connectors on the main board are soldered together is it supposed to be like that?
Jake
The Stable:
Midnight
Post by Midnight »
Well I re-soldered the connectors like they were and the displays all work. But now when I have the headlights on and turn on the turn signal on, both arrows flash and the dash back lights flash opposite them. Grounding issue? Anybody know specifically where to look?
Jake
The Stable:
Midnight
Re: Jakes '91 200 Avant: Spark-less
Post by Midnight »
I thought the 200 was reliable enough to daily :shame: So I sold my A6 on Sunday to make room for a truck. I drove the 200 40mi up into Wisconsin tonight with my dad to go look at an f250. Just as I started going through the gears after I dropped him of at his car I noticed the 200 was bogging down a lot so I popped it outa gear and rolled of into a parking lot. Glanced down, and she was dead, tried to restart and she cranks over but wouldn't start. I got as far as figuring out that the coil isn't firing before it got dark. Then we broke out the tow rope and drug it back to my dads office parking lot. Then he said something about hooking the computer up to it and I remembered that the last time I scanned it, there was an error saying that the engine speed sensor was bad. But the car was running fine, so I kinda forgot about it. :bangshead: How big of a job is it to replace the engine speed sensor? It looks like its under the PS res correct? It there anything else I should check before replacing the engine speed sensor?
Jake
The Stable:
WOMBAT
Post by WOMBAT »
There's 2 sensors there looking at the flywheel and ring gear - replace them both; not hard to do. Cheapest price I've found is on ebay and I'm running the ebay sensors now without issue. Also check that the distributor is still spinning in case the gear has broken.
They are SUPER easy - You just need a small allen key (But clean the area and use penetrating fluid or you WILL break the Aluminum POS bracket that it uses). They are on the driver side right where the flywheel is like wombat said
I bought this one below that replaced both g28 and g4. If I were you I would replace both since your car 'should' be able to run with just the g4 crank sensor running - check your wire orientation too!
As a bonus mine actually came in an OEM beige color and works wonderful.
http://www.ebay.com/itm/NEW-CRANK-POSIT ... b9&vxp=mtr
Also consider yourself lucky that is a very small problem in the grand scheme of things :D
Midnight
Post by Midnight »
Finally got both sensors replaced but its still not starting. Its all tore apart for a timing belt job right now. I'm going to check the distributor once I get the belts back on and replace my seized A/C compressor.
In other news, my dad bought another silly Swedish car yesterday. So, I get to drive his old 9-3 until I get my car back on the road.
Jake
The Stable:
AngryTaco
Post by AngryTaco »
Is the timing pin still in the flywheel?
Midnight
Post by Midnight »
AngryTaco wrote:Is the timing pin still in the flywheel?
:idunno: I would have to separate the engine from the trans to see it, correct?
Jake
The Stable:
AngryTaco
Post by AngryTaco »
No either look through the sensor port or remove the starter
Midnight
Post by Midnight »
Finally got to work on the car last night, checked timing, including distributor. Pulled the g4 sensor and stuck a borescope in the hole but I couldn't find the timing pin.
Then I got kinda distracted when my neighbor came over with a Tesla he brought home from work (Tesla dealer tech). We drove it around some and he pointed out some of the flaws with it, its a nice car but the fact that Tesla is still a new company really shows.
Will pull the starter to look again for the pin this weekend hopefully.
Jake
The Stable:
Midnight wrote:Well I re-soldered the connectors like they were and the displays all work. But now when I have the headlights on and turn on the turn signal on, both arrows flash and the dash back lights flash opposite them. Grounding issue? Anybody know specifically where to look?
Weird, I am getting the exact same cluster problem… haha so I guess it's "common"
Midnight
Post by Midnight »
Crap
Jake
The Stable:
AngryTaco
Post by AngryTaco »
drill it out through the starter hole and tap in a new one. That or weld
Midnight
Post by Midnight »
AngryTaco wrote:drill it out through the starter hole
My clutch is on the way out anyway. Im going to pull the engine, clean it all up, replace the clutch and flywheel, and put all new hoses on.
Jake
The Stable:
yodasfro
Post by yodasfro »
Good idea to replace the clutch considering it was probably a ball bearing from the throw out bearing that took out the the timing pin.
Midnight
Re: Jakes '91 200 Avant - Back in Action
Post by Midnight »
Wow its been awhile. Long story short, when the timing pin broke I parked the car and focused on other life moves. Like going to college. I ended up getting the car out over winter break, the engine came out, flywheel in the Bridgeport, new pin, back together, and :drive:
It's still mostly the same car it was before, but today the power steering and power brakes became intermittent. They will both come and go together and the BRAKE light comes on when they go out. The Bentely points to a hydraulic pressure problem, but I haven't found much about that online. Anybody have any experience with these symptoms?
Jake
The Stable:
It's definitely a hydraulic pressure problem. The brakes and steering are both assisted by the power steering pump. If you are low on fluid, have a bad leak, some other pressure problem, or the pump is bad, you will experience the problems you've described.
88a5tq
Post by 88a5tq »
I had intermittent problems when a piece of blister foil that fell in the hyd fluid bottle went in the reservoir and kept flopping around in a specific banjo fitting. Came and went constantly.
Midnight
Post by Midnight »
Found a leak. One of the banjo fittings at the pump got pushed up against the rad. end tank when I torqued the banjo bolt, came loose when the engine started moving around.
Audi also got featured in one of the guys snow drifting videos.
Donuts at 6:00-6:20 & Launch at 8:30
[youtube]https://www.youtube.com/watch?v=S775tjsj-Vk[/youtube]
Jake
The Stable:
88a5tq
Post by 88a5tq »
Should've been more footage! Your launch was better even :) locked rear?
Midnight
Post by Midnight »
Ik, I was hoping for more footage of me, but the camera was in the lead car most of the night. Launch was 6500RPM, 2nd gear, rear unlocked.
Jake
The Stable:
Buncha hooligans! :D
Midnight
Post by Midnight »
8-) We Automotive Tech majors know how to have fun.
Jake
The Stable:
