Horsepower guesses, anyone?
By looking at my log, can someone tell me approximetly how much power my motor makes?..
- v3.3_u004857-2014.07.15-17.48.11.vemslog
- (111 KiB) Downloaded 1192 times
Re: Horsepower guesses, anyone?
Fuel type, injectors, and turbo?
Edit, I'd say at least 100whp
94 octane.
7A cams, 4 degrees retarded.
.5mm in/ex. valves
1000cc injectors.
S362 extended tip turbo. Compressor 62/83, turbine 75/68
.5mm in/ex. valves
1000cc injectors.
With those timing numbers, 400, 450whp I'd guess. That's a base timing map looks like.
Get on a dyno or make up some knock phones. You'll make a lot more power with the same fuel usage. 500+ on pump I'd say
Dutchbroracer
I have no idea. Nice setup though
Hank is pretty good at figuring it out.
More than 10 and less than 1000.
