loxxrider wrote:So with shortened housings and re-valved struts how is it? How is the low? How is the damping?
The low is nice, verrrrrry nice. I have probably 1/4" left to thread down and I can just fit my flat hand in between the wheel and fender(front and back now). I still have plenty of ground clearance, getting out of my sloped driveway with a rounded curb isn't a problem. With #550 and #650 springs in front and rear respectively, It has very little squat when I take off quickly which is a dramatic change from before. I have very little body roll but am limited by the stock 200 seats...I start to slide in my seat mid turn so it limits how fast I can take them.
As for ride quality I've experienced better. With the car being low, stiff, and on thin tires it is no where near annoying or uncomfortable though. I can actually feel the paint lines in the road more in my 2010 KIA Forte Sedan more than the Audi. I thoroughly enjoy being able to feel every variation in the road though, so it may very from person to person.
It's probably as low as I'll ever take it, I don't want the oil pan any closer to the ground. I may consider building a plate to guard the bottom of the motor/belts from road debris soon. As stated before with 235 40 18 tires on a 18" X 9.5" et20mm offset wheel I have no rubbing, which is a shock to me.
I think the biggest problem/complaint about the ride is the lack of a rear sway bar. Going around turns you can really feel the back end move.
All in all this car has been extremely friendly with going low. I haven't had to notch any frame or make any dramatic changes that would sacrifice quality and safety.
The top strut mounts work well so far and I will keep updating how they are holding up and performing. My biggest concern with making them for sale is thateveryone has their own set up. My choice of top hat, shocks, springs, helper spring, etc may very and cause clearance issues which I did not design or allow for. If you PM specs(dimensions) of hats, etc of what you have I can check and see if other parts will work. I feel the A1 Racing hat is taller with a longer lead in and will fit better than the Bicknell hats, but you also lose .5" - 1.0" of low.
Oh and I personally think the 200 looks sexy with the wheel choice, fitment, and ride height. That's just me though.
-2014 Lexus IS350 - SOLD
-2015 Yamaha FZ-07 - SOLD
-2005 Honda CRF230F - SOLD
