Convert VEMS econo seal to PNP for URS4.
vwnut8392
Post by vwnut8392 »
Im picking up a VEMS ECU second hand but its an econo seal version. im capable of making the jumper harness to go from the econo seal connector to the motronic connector. my question is if i have to make any changes to the board itself for the AAN cam and crank sensors to function properly? also what diode do i need to put inline with the ISV to make it function properly?
84 4000S quattro-AAN swapped
83 UR quattro
95 URS6 avant
95 URS6 sedan
90 90 sedan-AAN swapped
91 200 20V turbo
92 GTI VR6
92 GTI G60 X-flow turbo
86 16V jetta coupe
Re: Convert VEMS econo seal to PNP for URS4.
depends on how the triggers are setup in the ecu you bought.
is it VR/Hall, VR/VR, or VR/Auditrigger?
vwnut8392
Post by vwnut8392 »
actually the guy im getting it from said that he bought it from you marc, he said he was going to get in contact with you about a build sheet or something. i did ask him that and several other questions about the ECU hardware but all he knew was it was a V3 ECU. he was including the 60-2 crank seal sensor with it as he said it runs on that sensor ad the cam sensor i guess.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
vwnut8392 wrote:actually the guy im getting it from said that he bought it from you marc, he said he was going to get in contact with you about a build sheet or something. i did ask him that and several other questions about the ECU hardware but all he knew was it was a V3 ECU. he was including the 60-2 crank seal sensor with it as he said it runs on that sensor ad the cam sensor i guess.
thats a hall type sensor, so I'll assume its setup for hall/hall. get me the serial number and I can look it up.
vwnut8392
Post by vwnut8392 »
alright will do! i'll be contacting him tomorrow and i'll get that number.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
vwnut8392
Post by vwnut8392 »
I didn't get the serial number yet but he sent me these pictures.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
vwnut8392
Post by vwnut8392 »
actually the serial number is in the second picture at the bottom, i just realized it. its 6505.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
bradyzq
Post by bradyzq »
DIYAutotune (and probably others) sells a DIYBOB breakout box for the 55pin ECU connector. It's a pretty tidy piece, and saves you a lot of work.
HTH.
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
we have the jpt55 connector as well (new), $50.
so, you have two basic things you are going to need to do to make that ecu work hardware wise for audi trigger
1) convert the primary from Hall to VR
2) convert the secondary from hall to auditrigger
for #1:
make sure there is a primary trigger lm1815 on the board (by default there is, even if it isn't setup with primary trigger VR). if its not there, add it.
open SJ2
short SJ6
for #2:
add the 2nd lm1815
short sj7
JP5 and JP1 2k7-10k(Optional for sectrig scope)
JP1 and GND 5v1 zener diode cathode to JP1
R248 2k7
Remove the 0Ohm 0603 resistor, and put an NPN transistor to that place(Bottom -side, near JP7)
SJ4: Connect the middle to the +5V(face to econoseal)
Connect EC18 pin 12 to the input of the 2nd lm1815, namely JP20(first remove ec18/12 from mcp3208)
Verify R59, should be 1kOhm
things that will help you:
schematics for the top and bottom boards so you can find all the solder jumpers (SJ) and pins I have referenced above:
http://www.vems.hu/files/genboardv3/v3.6/
vwnut8392
Post by vwnut8392 »
Thank you Marc! I have one last question, do you have this hardware I need to add and can I buy it from you? I have the motronic connector already, I robbed an old BMW ECU for one lol.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
bradyzq
Post by bradyzq »
Marc wrote:we have the jpt55 connector as well (new), $50.
Didn't mean to step on your toes!
I thought he was making a harness and keeping the Econoseal connectors. That's where my suggestion was aimed. Easy-peasy adapter box.
If he's changing connectors at the ECU box, of course it makes sense to buy the 55-pin connector only, and buy it from you!
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
vwnut8392 wrote:Thank you Marc! I have one last question, do you have this hardware I need to add and can I buy it from you? I have the motronic connector already, I robbed an old BMW ECU for one lol.
I do have the necessary chips yes, I'll have to look up pricing, we dont normally "sell" them, usually used internally when we have to reconfigure a box.
vwnut8392
Post by vwnut8392 »
Im sure i can get everything from like mouser.com or digikey.com but i wanted to make sure i got all the right stuff. Im still waiting for the ECU to get here so i can see what's what with my own eyes. I think im over complicating the modifications in my head from all the information i've read on making this work. the VEMS.hu wiki makes it a bit confusing because of all the revisions and people trying different things not to mention its not the most organized wiki.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
vwnut8392
Post by vwnut8392 »
does anyone know if this will work in place as the second LM1815?
http://www.mouser.com/ProductDetail/Nat ... Ogodwj8ADw
Im trying to figure out what the rest of the hardware i need to get as well, any input would be a great help.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
Why are you trying to substitute for the lm1815? They're pretty cheap
I'd look around the MS forums most MS VR setups use them so you might find your answer there
vwnut8392
Post by vwnut8392 »
i wasnt trying to find something to replace it, i was just trying to find another one. marc is helping me out with whats needed to convert this over now.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
Digikey has them for like $3/ea
vwnut8392
Post by vwnut8392 »
Well thanks to marc i got the hardware i need to add. i have most of it installed but i have a few questions about some of the hardware still.
So far i unbridged SJ2 and bridged SJ6 added the second LM1815, Bridged SJ7, added the resisitor to R248, removed the 0 ohm resistor and added the NPN transisitor.
I just labeled on the VEMS schematic to make it easier to see what i did and what im trying to figure out yet.
My first question is where to get the 5V+ for SJ7?
Next is JP1 and GND 5v1 zener diode cathode to JP1. Which is JP1? each of these pads connect to different pin on the processor.
Now the Connection EC18 pin 12 to the input of the 2nd lm1815, namely JP20. Which side of the jumper goes to EC18-12? in the diagram below i have the bottom side of the board.
lastly i dont understand JP5 and JP1 2k7-10k(Optional for sectrig scope). if the zener diode goes on JP1 how do i add the resistor as well?
i have 2 resistors left after adding all the hardware too. sorry for being such a pain about this but i dont want to screw it up and ruin my ECU before i ever even get to drive my car on it. Ive tried to find pictures of other ECU's that have this modification done but it seems none of them have anymore than the 2nd LM1815 added, SJ6 and SJ7 jumped.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
here are some board pictures for you of a pnp (a fairly early one, but perhaps still useful for you). I'll try and answer your questions tomorrow but no promises. bunch of stuff going on right now. http://www.theswansonfamily.us/modules/ ... internals/
vwnut8392
Post by vwnut8392 »
i have everything figured out except the zener diode on JP1.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
Wheeljack
Post by Wheeljack »
Isn't the blue line just going to a via, not a pad? You want it on the yellow pad, I would think.
http://brydon-eng.com
vwnut8392
Post by vwnut8392 »
well i tried to start my car less the zener diode and it will not start. i have searched for like a week straight when the list was posted and i cannot find any information or pictures of anything in the JP1 position. i've looked at the pictures marc posted and and the ECU pictured doesnt have anything in JP1 either. for the 5v at SJ4 middle pad i read in the VEMS wiki to add a jumper wire to pin 8 of the LM1815 for 5V there, im not sure if this is accurate. i seen injector pulsewidth but nothing for spark related would move in the gauges when cranking. i have my ISV unplugged as well because i know there's a diode that comes in a jumper harness for the PNP ECU's as for what it is i dont know and i dont want to take any chances. i fear it may harm the ECU if i have it plugged in.
This is what i have now.
You can see the jumper wire in the diagram from pin 5 to pin 8 on the LM1815 and i labeled lower hole on JP20 because thats now tied to EC18-12.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
vwnut8392 wrote: My first question is where to get the 5V+ for SJ7?
you mean SJ4. the reason that solder jumper has 3 pads is you can select what you are sending to sj4 input pin based on which pad you solder. in your photo, connect the bottom 2 as shown in your photo and it will bet set to +5.
regarding jp1 its actually neither of the lines you have drawn. stripe of the diode faces the upper left hand pin, other side of the diode can go to either of the two large through holes on the bottom, they are both ground. but on this PnP here in front of me they used the one diagonally across from it on the bottom.
top top hole is the ground plane (see it connected to the huge pad via those 4 points?). bottom hole is the signal pin path.
in parallel. axial components are easiest or just solder the resistor to the board and then the diode to the edge of the SMT resistor.
hope that helps!
