Favorite Custom Connecting Rod Manufacturer?
AngryTaco
Post by AngryTaco »
GO!
I'm thinking pauter for my application
Need BE Bore to be 46mm
Length -- 144mm
Wrist pin -- 20mm
alxdgr8
Re: Favorite Custom Connecting Rod Manufacturer?
Post by alxdgr8 »
Hank has a company that does custom H-beam rods for a good price, I forget the name. Maybe he'll chime in or send him a PM.
alxdgr8 wrote:Hank has a company that does custom H-beam rods for a good price, I forget the name. Maybe he'll chime in or send him a PM.
DMForged
http://www.irozmotorsport.com/search.php?search_query=rods&x=0&y=0
You would be a fool to keep the MC crank if you are building a motor. No ACL rod bearing are available for that BE. Grab a 7a/NG/AAN/3b crank and build that up if you are hell bent on a 2.2, or grab a eurovan motor and just use it.. Shoot, I bet you could machine TDI pistons to get down to 10:1 pretty easily. I have 6 TDI tall decks here in the shop that I will probably just throw the rods and pistons away on. Jim Green has a Eurovan bottom end for sale in SoCAL and he will be up to Vegas in a month or so. I could get it to SLC after that pretty easily.
Of if you want to use a non ghetto bottom end, 236mm tall deck plus 159mm rods plus ABA pistons(preferably forged aftermarket) would get you what you want. As the only 20vt guy around, you are lucky, as there aren't as many mods needed to run a 20v head on a tall deck.
I also have a cheap complete 20v head :)
AngryTaco
Post by AngryTaco »
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!
The only 20v I will get into is the 07k I plan to drop into the treser I plan on picking up
Also, jim you have pm
AngryTaco
Post by AngryTaco »
How much machining are we talking to get an MC head on a diesel block? What is involved? I have been considering finding the tall deck for some time now but I'm not sure whats involved with machine work
PRA4WX
Post by PRA4WX »
Not sure why 20v you'd want to bother with the diesel block when you can easily go with the gasser 2.5/20v. I have been saying its the way to go staying 20v.
