Looks like I may be buying a TIG welder this week. I'm looking at a Miller 3-phase High-Frequency Dial Arc. Guy is including all the TIG attachments, a water cooler for the TIG, Stick attchment, cart, bottle of argon, and all hoses. Any one have experience with these and what do you think of them? Need to weld Aluminum, Stainless, and mild. Possibly Ti in the future. The guy is asking $1100 and its in like-new condition.
I'm going to start producing custom manifolds
Heres the link: http://spokane.craigslist.org/tls/4319543816.html
should I buy this welder?
Re: should I buy this welder?
I think it's a little high priced given its age but probably in negotiation range. It's ac/dc so will do pretty much anthing you can TIG.
One thing to keep in mind with older TIG welders is they need a LOT of amperage... figure at least a 60-75 amp circuit to run this. This is the reason my Synchrowave 300 sits all lonely in my garage at the moment is I don't have a circuit large enough to run it (and I don't own the place so I'm not adding one... have to wait til we buy a house).
Here's a manual for it... miller has a lot of great resources on their website.
http://www.millerwelds.com/om/o315k_mil.pdf
Bill J
'12 GTI
'88 90 Quattro
'13 Mazda 3 (wife mobile)
2001 Chevy Express 3500
and two tube chassis in progress, Mid-engine 07K '73 Beetle, and Miata powered Locost
'12 GTI
'88 90 Quattro
Thanks for that! We are already setup with a 60a circuit so I'm thinking the TIG function will be ok. I am worried about it if I have to use stick on thick material < .25" thick but I just dont see that happening. If I need more juice, I'll wire another outlet in the shop meant for 100a
JustinB_20vt
AngryTaco wrote:Thanks for that! We are already setup with a 60a circuit so I'm thinking the TIG function will be ok. I am worried about it if I have to use stick on thick material < .25" thick but I just dont see that happening. If I need more juice, I'll wire another outlet in the shop meant for 100a
FWIW I have a dialarc HF 250 (non power factor) version and it recommended 150A breaker. I run it on a 125 amp two pole single phase.. great welder but without the AC balance a syncrowave or some of the newer welders have welding aluminum can be tricky.
Justin aka banget3k
Yeah thats what I've come to conclude. I'm seriously looking at a 225 Lincoln or a 220 Miller inverter unit. It all comes down to $$$ right now
If you have the room the older Synchrowaves are great welders... but like the Dialarc they're power hogs and a fair bit larger than the Dialarc.
I bought my Synchrowave 300 for $650 about 4 years ago with a new watercooled torch, lead, and lead cover... there are deals around if you look (found mine on EBay).
like I said, not a small rig...
Bill J
'12 GTI
'88 90 Quattro
'12 GTI
'88 90 Quattro
JustinB_20vt
Heh small... I amost bought an Miller Aircrafter a few years ago which is like a syncrowave only heavier.
Justin aka banget3k
There are a few Synchrowaves around but a bit of a drive. Do they have the fancy stuff like arc control and the cleaning functions?
JustinB_20vt
I am in no way an expert on this but they are a step up from the dialarc in that they are a constant current vs constant voltage and have ac balance which you need for quality aluminum welding. The newer digital ones i believe have frequency for AC, step in, crater time etc but that's just fancy stuff for producing IROZ parts.
Justin aka banget3k
