Got a bunch of stuff knocked out this weekend! First off I finished my VR throttle body instal, and while I had the intake manifold off I installed my Siemens 830's. And then I figured there's no point in big injectors without a big fuel pump, so I put my new pump in too
It's actually quieter than the factory pump was! I used Mushasho's instal guide (
viewtopic.php?f=11&t=13&start=425). For my install I also needed to shave down the plastic reinforcements from the factory basket after I cut it off to allow the fat end of the Walbro to fit in. I didn't get any pics but it's pretty obvious when you get in there, just have a dremel handy.
Also, the factory fuel line didn't fit the new pump, so I went to Advance hoping they might have a special flex fuel safe fuel line. Nope, so I just bought 2ft of fuel line the diameter of the Walbro stuff. It doesn't look like it's going to be an issue according to a quick search, what do you guys think? Then I cut the factory fuel line just below the end of the banjo on the wiring panel side and left the factory black line over the banjo as a spacer to make the fuel line fit.
Then we went out for a drive, I made a rookie move and destroyed my fuel map without saving, so I had to recreate it and Ben and I had to push start the Audi a couple times, but I got a good tune on it and got it smoothed out and it runs great! It was late, so I got the cruise about where it needs to be, and we did some pulls, I basically just made sure it dropped to ~10 around 5psi and got that evened out across the rev range, cleaned the whole thing up a little more and called it a successful night. It was really just to run the car and get a base fuel map as the car won't get beat again until the new trigger setup is in this week
