With the flywheel on and the engine bolted to the trans I got the cam/crank timing set and the belt on, the distributor in and set about where it needs to be. I wrapped up the coolant system, just needs fluid, got the fuel system closed up, and a few other misc things. Looking pretty good for tomorrow, assuming I can find the right capacitors I'm missing on a board here at work. If not I might go with "close" values and hope it works.
Getting home
Timing set, fuel system buttoned up, distributor in, getting close to ready for first start
This is when I decided to let the snow fall and work on it when it's at least not actively covering anything exposed
So I went inside and moved on to electronics stuff. Since I'm going to break the engine in on the old MS setup I needed to build another coil driver circuit as I destroyed mine and wanted to make this more temporary so I built this guy.
And started working on my main extra board. This is mostly for pullup circuits, 5x for COP's that you can see already built, the two fuses for Fuel injector 12v+ and the 2 amp fuse for the ECU. This should allow me to keep most of the extra circuitry off the MS board to help with noise issues the 2.2 boards are prone to. I added another 5v regulator so that this board has it's own separate 12v, 5v, and ground plane. I still need to move/add a couple circuits but you can at least see it taking shape.
Thanks for reading along!
