Re: Taco's 4KTQ 20vt Swap: The Red Baron - More VEMS Prep
Yeah and no codes. Have you ever had a high lift cam with CIS? If I throw an MC2 cam back in, I wont have issues
Got the B6 back together and running today. Giving it back to the owner tomorrow
Managed to even break the stupid snapon #10 RIBE headbolt tool. Shattered into a bajillion pieces
AudiSport4000
I never did, mainly because I didnt want oneAngryTaco wrote:Yeah and no codes. Have you ever had a high lift cam with CIS? If I throw an MC2 cam back in, I wont have issues
EFI EFI!
1986 4kq Commemorative Design
2012 Jetta TDI
2012 Jetta TDI
Ok people. I need some powerflex and motor mount sales so I can buy VEMS!!!!!
Arggggh. While the dodge is in the shop getting the midpipes fabbed up, I started tearing off the passenger strut to finally fix the damn bad hub once and for all. But nooooo, the bastard strut nut doesnt want to cooperate......ugh. I really need an electric impact gun.
Once the hub is all buttoned up, all I'll need to finish the front suspension is some 325# springs and some urq revalved HD bilsteins
Finally got a good hub with a good bearing installed into the passenger tower. Now I can FINALLY go and get a damn alignment
Yeah... not looking forward to that when I get it done. The rear is way out, and the front has a ton of new parts. I'm sure nothing is even close to what its supposed to be lol
just point everything to the left and make a stock car out of it
Is that what you are going to do with the truck?AngryTaco wrote:just point everything to the left and make a stock car out of it
hell no, that thing is going to be a road course monster
So started playing with the VEMS software today to familiarize myself with it......holy crap is it different vs my Dodge tuning software. This is going to take some time. Good thing I have another few months before I'm ready to even buy the ECM
Yeah, I said the same thing when i first looked at the MS tuner studio. Lots of different things to .monitor and change. Should be interesting.
yeah, it takes a while to figure out where everything is and then you have to remember that for next time. it takes some messing around with, but with friends that know how to help and some direction from Marc, its not too bad. He has helped me out a ton and I hav'nt called him hardly at all. it really comes down to having a solid base tune that you can start from, after you get all the basics dialed in like setting TDC for your timing. There is heaps of stuff to mess with that I have no idea what it will do, or how it will affect the car. all in all, I'm glad he includes tuning with the purchace of the ECU.
If only the community college offered a course on tuning with Vems. it would take a whole 1/4 to get through everything and be sufficient. But it would be one hell of a fun class!
Well did Taxes tonight......$2040 back!!! Guess who is getting VEMS in the next month?!
At least congress got the "American Oppurtunity Tax Credit" right
Frick ya dude. make it happen!
hmmmm....or do I invest in a TIG welder for HPR? Or finally finish the front end on the dodge!? OR buy new tires for the dodge!? SO MANY CHOICES!!
Re: Taco's 4KTQ 20vt Swap: The Red Baron - Which Fuel Inject
Ok everyone. I need some information from yall.
How much fuel pressure are you guys normally running? I have to decide how big of a fuel injector I need to buy. The ultimate final goal is 525 wheel hp. So roughly 630 crank hp or so. I'm thinking the 1100s chris sells would be sufficient. But I'd rather calculate my needs first
Just make it easy and get as big as you can afford
well problem is I only want to buy ONCE. I still have to buy the VEMS ecu, the LS2 Coils from varia, possibly a harness, fuel injectors, fuel pressure reg, and a bunch of other misc crap. After that is all done, I have to send the urq cam off to be reground, buy new lifters, etc etc etc etc.
buy my mounts
buy my mounts
Personally I'm running a 4 bar FPR for now. Once I go E85 I will need to step up my game to around 6 bar of pressure.
- amd is the best
Why do you plan to run such a high base pressure?85oceanic wrote:Personally I'm running a 4 bar FPR for now. Once I go E85 I will need to step up my game to around 6 bar of pressure.
I think 630hp roughly = 600cc injectors... so buy the 1100s and be prepared for corn. haha Like Matt said, get the biggest ones you can afford that will still idle smooth.AngryTaco wrote:The ultimate final goal is 525 wheel hp. So roughly 630 crank hp or so. I'm thinking the 1100s chris sells would be sufficient. But I'd rather calculate my needs first
Better atomization?amd is the best wrote:Why do you plan to run such a high base pressure?85oceanic wrote:Personally I'm running a 4 bar FPR for now. Once I go E85 I will need to step up my game to around 6 bar of pressure.
Yeah I'm going to have to run E85 minimum. On the track, since I have easy access, I'll run 112 octane, and possibly e98 or 114 race fuel for max powah!
I mean hell, I'll be running 10.5:1 compression too
- amd is the best
6 bar of base pressure is 87psi. Add 20 or 30psi of boost on top of that and your looking at 120psi of fuel pressure. Not many pumps are even tested that high and most will run out of steam by that point.
My stock fuel pump is running over 120psi right now on the CIS system. Then again, I think the most fuel being allowed to move is a total of 660cc/min due to the fuel dizzy being the limiting factor
