Re: Ben's Oceanic PTE5857 AAN 4kq - #1 Damage :(
Sounds like I should have hopped in when Joe did. Real sorry to hear, Ben. Glad it's nothing terribly serious though!
40v4kq
Post by 40v4kq »
Sorry to see this Ben. Luckily I know a guy that something like 3 3b's just laying around. Maybe you can put one to good use while you fix/build your engine ;)
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
PRA4WX
Post by PRA4WX »
Sorry to hear this Ben. Good luck with the rebuild! 8-)
Thanks guys. :)
loxxrider wrote:
I wonder what the cause was... was it simply from a lean condition over a long period of time making the mixture very hot or was it from too much timing advance? Either one could induce det. With Hank and Marc riding with you, I'm sure someone noticed one of the two...
Thank you for the nice write up Chris. I appreciate it man. SO, as for the DET, timing was involved for sure but mostly it boils down to overboosting the crap out of it without a good clean tune for the pressures I was hitting. Ultimately, I believe this could have been avoided if I would have hooked up the MVR correctly the first time because I had ZERO boost control on the trip down. :hammer:
Also, just a quick update:
For right now the car is going to go on the backburner while I recoup my finances from this trip and all the money I have thrown at it this summer. But I do have a plan:
-Wiseco Pistons (82.5mm)
-SS Exhaust and Intake valves
-Mild port/polish
-Crankshaft balancing
-TI retainers
-Light weight lifters
-ARP main studs (for bottom end)
- and any machine work needed (of course).
I would like to be able to comfortably rev to 8000-8300 RPMS. :)
2.5TYPE44
Post by 2.5TYPE44 »
It's a slippery slope! :D
AngryTaco
Post by AngryTaco »
85oceanic wrote:
-Mild port/polish
What a crock of shit! We all know you are going to go hog ass wild on those ports! Those ports better be bigger than Dave's and Mine!
AngryTaco wrote:
85oceanic wrote:
-Mild port/polish
:lol: :lol:
40v4kq
Post by 40v4kq »
Well, if only the number 1 piston is damaged why not just find a good stock piston to throw in there and then you are back in business while you build your spare block, and then when the time comes rip the head off to build it and stick it on the built block and stuff that in the car?
Dan
1984 Ur quattro
40v4kq wrote:Well, if only the number 1 piston is damaged why not just find a good stock piston to throw in there and then you are back in business while you build your spare block, and then when the time comes rip the head off to build it and stick it on the built block and stuff that in the car?
Well, with the amount of visible damage I can see, I'm afraid the cylinder bore is going to be all jacked up and on top of that I am pretty sure that there is going to be some head damage that will need to be welded up. While I have it all apart, at a BARE minimum it will need SS valves, head work, #1 piston (provided the others are all jacked too) and a hone or bore. So I guess where I'm at, is I just need to build it to a level where it will handle getting beat on at the power levels I want.
Oh and pissed off taco, most likely it will turn out to just be a gasket match situation because I don't have access to a flow bench.
It should be good as is to beat on for pretty much whatever power levels you want. The ss exhaust valves are a good idea but stock pistons and bore are fine. But I understand you may need to bore if you want to use the same block.
When I had my massive det I just scraped off the head, put stock pistons in a"new"block with a hone, and slapped it back together (New hg). There was no real damage to the head. At what point do you need main studs?
bradyzq
Post by bradyzq »
If it turns out that all the damage is in the #1 hole (insert crude joke here) then I suggest finding out why it was so massive yet only on one cylinder. Check for a bad injector or wiring, etc.
Hope it's not too bad when you open it up.
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
Brady I think next time I'm in Montreal with the 4kq (as in... when I plan that lol) I'm gonna drop by.
bradyzq
Post by bradyzq »
chaloux wrote:Brady I think next time I'm in Montreal with the 4kq (as in... when I plan that lol) I'm gonna drop by.
You're always welcome, tuning or not!
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
loxxrider wrote:I agree, you don't want to run 91 octane with that setup. With 93 though, one could argue that you'd have plenty of available power. Consider a flex fuel setup so you don't always have to have E85 and don't have to care about testing it
For those of us stuck with 91 only, what about mixing in toluene? Would that be consistent enough, say going by an online calculator, to tune for 93 octane levels?
I can't comment on that, sorry! I think the answer is going to be along the lines of the idea that you wont really know the true ocatane rating of the mix unless there is some ratio you can use... You could always try it and listen for det though (assuming that stuff is safe to use). Like I said, I have no idea...
scubadave
Post by scubadave »
85oceanic wrote:Oh and pissed off taco, most likely it will turn out to just be a gasket match situation because I don't have access to a flow bench.
I dont have a flow bench either. Never stopped me. just gotta know how far to go, what to cut, not to cut. However, its not for everybody, and it does take a bit of finesse. no biggie if you're not willing to risk your head. I practiced on a 20v head in fact...but that head was destroyed....by a taco. You're going to need some tools $$$$$.
I agree with the flex fuel setup. I already have one and plan to use it. why bother with anything else? besides, anybody really want to mix your own chemicals and get cancer for your troubles? F that shit.
AngryTaco
Post by AngryTaco »
According to Nazifornia, being alive is the number one reason of death. Also, traveling to LA involves breathing in chemicals known to the state of brokeazzfornia that may cause cancer or stupidity.
Also, mixing chemicals is fun!!
40v4kq
Post by 40v4kq »
Hey Taco, you ever seen all those wind generators down by LA? Yeah, those are to blow all that crap up to Udaho. I personally farted behind them just for you. lol
Dan
1984 Ur quattro
AngryTaco
Post by AngryTaco »
All those windmills in the palouse blow it right back down to you in Sacramento!
PRA4WX
Post by PRA4WX »
Lol at AngryTaco! You are one funny dude.
Mmmm.... :)
Less tease and moar 3/4 and profile views please.
Bummer to hear this Ben. It's happened to all of us, in fact, I am convinced everyone should blow up a 20vt learning to tune before they jump into a nice 20v setup :)
