Re: Taco's 4KTQ 20vt Swap: The Red Baron - VOLVO K24 ON THE
I needz moar efficient boost
scubadave wrote:Hey now, love the turbo...but don't loooovve the turbo. Mkay?
I was thinking the same thing!
I tried to put up the robot chicken humping robot gif but can't make it work on my phone.
Edit...nevermind, fixed it with my tablet.
MAH TERBOZ HAZ ARRIVEZZZDDDD!!!!!!
Is it running yet!?
It depends on how I feel honestly. I might do it before I drive down to Bens place in a couple weeks for our epic pre-bbq weekend
Do it or... I dunno. I guess don't.
lol
DO IEEEET. I need another red 4ktq to look at. One that fakin works
lol
Lol. I decided if I have all the parts by Friday, Ill do it this weekend
diff en route
Yay!!! Going 3.89s beotches. Damn you Dan!
ERMAHGERD MAH PORSCHE TERBOZ PARTS ARRIVEZZZZ TODAYZ!!
Good, now get them all put together and installed! Im sure it wont take you too long.
Wouldnt the first thing be to take the wbo2 out of the truck and stick it in the 4k......?
Youve been talking to ben havent you?
Lol. Im working on it
No freaking joke.GTJeff wrote:Wouldnt the first thing be to take the wbo2 out of the truck and stick it in the 4k......?
Who needs a wideband when you have a narrowband and a natrix chipped ecm?!
Re: Taco's 4KTQ 20vt Swap: The Red Baron - VOLVO K24 IS HERE
So finally got everything in. As requested, I have posted the following pictures showing the difference between the modified audi k24 housing and a stock porsche K26 #6 hotside. It's quite noticeable really.
Here it is in all its shiny glory after I mated it to the porsche K26 housing
Porsche K26 exit bore diameter
Porsche K26 entry diameter
Modified Audi K24 Exit Diameter
Modified Audi K24 entry diameter
Porsche K26 Entry Way
Audi K24 Entry Way
It's really hard to tell from the last 2 pictures, but the Porsche K26 has a much larger runner going into the turbo housing. Me and scubadave believe this is a good reason to his detonation issues. The exit diameter on the Porsche k26 is a MUCH better fit with its 50.00mm diameter. I'm honestly not sure what that will change over the 51.xx mm exit diameter of the modified Audi K24. Perhaps a reduction in turbulence????
All I know is I'm going to polish what I can on the inside of the porsche hotside and enjoy the hell out of this turbo.
Audi K24 Entry Way
My name is Scubadave and I approve this message.
Ugh. Had a fight with the CIS tonight. Fired it uo after 2 weeks of sitting and it did NOT want to idle. After backing out the idle adjustment screw, it finally idled. I dont get it. 2 weeks ago it was fine. I do know there is something wrong with the fuel system. I hooked up a pressurr gauge between the WUR and the fuek distributor and measured the fuel psi after shutting the car off. It idl es at 55-60psi which is normal. Then upon shutdown it immediately drops to 15psi. Its only supposed to drop to 45psi after 10 minutes. Where the hell is my fuel going?! Ugh I am so ready for VEMS
Im highly suspecting the WUR committed suicide by boredom. I have a couple extras and all signs have been pointing to it, so Ill change it this weekend
Re: Taco's 4KTQ 20vt Swap: The Red Baron - DEATH TO CIS!!!
Couldn't a bad FPR be the culprit too?
The WUR is a fpr. Its real name is control pressure reg
- themagellan
AngryTaco wrote:Ugh. Had a fight with the CIS tonight. Fired it uo after 2 weeks of sitting and it did NOT want to idle. After backing out the idle adjustment screw, it finally idled. I dont get it. 2 weeks ago it was fine. I do know there is something wrong with the fuel system. I hooked up a pressurr gauge between the WUR and the fuek distributor and measured the fuel psi after shutting the car off. It idl es at 55-60psi which is normal. Then upon shutdown it immediately drops to 15psi. Its only supposed to drop to 45psi after 10 minutes. Where the hell is my fuel going?! Ugh I am so ready for VEMS
Mr. Taco - I had a similar issue on my 87 Fox with CIS - I ended up ripping off the CIS for a 32/36 carb but I realized when I pulled the injectors off it was simply that the injectors had some crud in them (Most noticeably in the Cold Start Injector) Give those bad boys a nice brake cleaner batch and check those lines.
YeH thats a good idea. I was going to buy a harbor freight ultrasonic clearing machine and soak them in seafoam
Well, another CIS problem. Dont know about you, but I dont forsee the current fuel system keeping up the the Volvo K24. I could be wrong though.
Dont know if you noticed, but there is a set of 550cc injectors for sale in the swap meet. hint...hint...
- themagellan
A volvo CIS unit is very cheap as well with a one or two extra Injectors along the way:) - search alaincopter on vwvortex for some CIS inspiration.DE80q wrote:Well, another CIS problem. Dont know about you, but I dont forsee the current fuel system keeping up the the Volvo K24. I could be wrong though.
