Removing power seat with dead motor?
DomP90
Post by DomP90 »
So i'm picking up a Corbeau seat to throw into my DD 90 since the fore/aft seat motor took a crap. Since the motor took a crap, I can't move the seat back to gain access to the bolts that hold it to the chassis, any tips on getting it out? Any way of moving the seat back manually?
thanks
'93 90q- 3m Matte Black Vinyl wrap, 17x8 et30 Rotiform BLQ, Koni Yellows/Vogtland springs
'90 Coupe Quattro- Project
varia
Re: Removing power seat with dead motor?
Post by varia »
DomP90 wrote:So i'm picking up a Corbeau seat to throw into my DD 90 since the fore/aft seat motor took a crap. Since the motor took a crap, I can't move the seat back to gain access to the bolts that hold it to the chassis, any tips on getting it out? Any way of moving the seat back manually?
thanks
its a nightmare. you cant really access to the motors to swap them so the bolt is your only solution.
(ive read, if you remove the motors along with that flex axle you will be bale to slide the seat, but i never could do)
so i had to undo the impossible bolts....
gl with it
¯\_(ツ)_/¯
project 2226
