Driveshaft hanger bearing
Mentosman42
Bought a replacement bearing from 034(first mistake) and after installing it the dust shroud on the u joint yoke is bound so hard inside the rubber of the bearing that I cannot get it to spin. Obviously I can grind down the shroud or take it off completely but anyone know of a bearing that will actually work without modification? Id be more than happy to throw this in a box and send it back to 034.
95.5 ur-S6
83 20vt urQ
83 20vt urQ
Re: Driveshaft hanger bearing
I know I've seen some pictures of a BMW one that's pretty much identical. I'll see if I can find it.
Here you go: http://www.motorgeek.com/viewtopic.php?f=15&t=32230
