40v4kq
Re: Ben's Oceanic H1C/K26 AAN 4kq - 01E time - Coilovers -
Post by 40v4kq »
Thanks phill, I think i have 7" springs so may run into the same problem you have if i went to 6". But let me check my rear, if they would work maybe id just step up the 450 in the rear. Then i could put a 4ks sway bar on the front to get rid of some of the sway.
Ben, then you could buy my 2 leftover 400lb'ers and jsut buy2 new springs. Unless you want phils springs...This is your thread so you can have the first crack at em :D
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
I would take your two left overs Dan! :D Have at em!
Mine must be 7" as well because mine are near the bottom.
Do you guys suggest 7"?
Also, Trans is ordered from from IMS, I will be picking up in Portland on the 24th. :)
85oceanic wrote:Do you guys suggest 7"?
Nice! I recommend 7. If you look at the pictures of my car, the front is all the way down and the rear is about half way. I don't think I'd ever want to go lower than it is now (in fact I'm giving myself just a bit more clearance).
Sometimes it's nice to have a few options for s-car parts around, lol... ie no buying a trans! You order all the other swap goodies along with it?
chaloux wrote:You order all the other swap goodies along with it?
Yessir, I sure did! I even got Hank's old Lightened AL flywheel. So all I will have left to pick up is the clutch.
Graygoose89
Post by Graygoose89 »
SIGH!!!
Ohh Ben, didnt trust me enough to get it here in Utah? ;)
Doug-
1989 Toyota Supra 1JZ-GTE Twin Turbo 5spd, 372rwhp/420wtq 22psi (stolen but recovered)
1991 Toyota Supra 19,818 Original Miles Sunroof
2004 VW Touareg (Wifey's Car)
2001 Audi A6 Quattro 4.2 (swapping 01E)
1998 Toyota Camry (Sold)
(^_^)
SIGH!!!
It's not that at all man! :) I am just being super cheap and I can get it to Portland for 120 bucks, then an extra 90 in gas. Where as driving to SLC was going to cost a bit more. :P
Audilard
Post by Audilard »
But if you came to SLC you would have seen my car and gone for a ride and that is priceless.
Darin
1989 80 20vt
Haha true story Darin! :P
Seriously missing my car right now...
40v4kq
Post by 40v4kq »
I know how you feel. My ECU showed up the other day but since i was at work they couldnt leave it. I may have to wait till thursday to get it :(
Dan
1984 Ur quattro
I know that feel too bro :(
Thirded :(
glibobbo21
Post by glibobbo21 »
fourthed...? :-)
Hell, it's almost time to start weekly group therapy meetings.
Seriously about to blow a gasket out of frustration...
Small rant: First and foremost, I will NEVER, EVER EVER go 4 bolt on a turbo again. I cannot WAIT until I get to be V-Banded... where is this coming from? Well, it's coming from stripping out and breaking off the studs on my turbo hotside. When I originally installed my down-pipe, I didn't want to fight having the nuts come loose, so I picked up some really amazing lock-nuts so I didn't have to worry about it. Well, apparently they not only locked on there, they fused. So when pulling the down pipe, they took the threads off of 3 of them, and the 4th stud snapped. SO at the time, I was pulling the trans so I let it slide. Fast forward to today, I go down to pull the studs out, well, even with my best stud removers (heat and a really legit snap-on pipe-wrench - plier hybrid thingy) they decide that it would be fun to strip out the threads inside the turbo housing. SO right now, I am livid because taping cast that is that thin really freaks me out. I cannot crack the housing. SO here I am, I only managed to get one stud out, one is stripped and just spins and the last one is broke off. SO rather than fight it, It was time to walk away. Anyways, word to the wise, V-Bands are a FAR superior method of mounting a turbo. Screw the stock 4 bolt.
Sorry guys, I just needed to vent.
I think you've got a problem with your nuts.
:rofl:
Seriously though, I've taken off a few turbz and never had that happen so bad. Motivation for 5757?
If I had the dough the 5857 would be going on asap but my wallet has been loosing a little too much weight lately. I have to make the H1C/K26 work for me for awhile longer. Also, I want it to be sellable once the 5857 goes on. :)
Vband FTW
AngryTaco
Post by AngryTaco »
Hey guess what.
My 20vt is faster :P
Hank wrote:Vband FTW
high temp antiseize FTW
antiseize doesn't allow you to remove your turbo in 3 minutes :)
Nor does it guarantee that your bolts stay tight. Anti seize has a way of being anti tight on a high cycle connection.
haha well u dont see me with a 4blt hotside
