Car:4000 with 20vt swap. 034 IB engine management using distributor/coil for spark.
Problem: weak and infrequent spark. Coil has 9-10v while cranking with battery fully charged.
Prior diagnosis: Here’s what I’ve tried: new coil, coil spark wire, tested hall sender, cap/rotor, checked negative and positive wires to coil, good grounds, and putting 12v from battery charger on positive side of the coil. When I manually trigger the coil with 12v hooked to the coil, I get GOOD spark off the coil but still won’t fire.
I miss this car and want to drive it! I’m 1.5hrs away from the car while I’m at college so I can work on it on some weekends with help from knowledgeable Audi guys. Any help is appreciated!
