the 01e uses an electric speedo that uses magnets to trigger an electric sender, while the 016 uses mechanical gear teeth to drive the speedometer.
016 passenger cv, showing speedo drive teeth location
the rings in the photos are a direct swap. some light machine work is necessary to fit the coupler into the side case.
photo showing m18x1.5 thread on the 016 mechanical speedo
01e with 016 mechanical speedo gear installed
01e side case with retrofitted 016 mechanical speedo
It is possible to swap the 016 mechanical speedo into the 01e. the "drive gear" is the same dimensions between the two. M18x1.5 threads need to be tapped into the housing for the sender to screw in, and the upper bore of the through-hole needs to be increased in size slightly (down to a depth of 1/4" or so).
Thanks Marc for the pictures. Hope this helps some URQs and 4000s!
we didnt use a fixture, calibrated eyeball.
