Hanks URQ 2.6L Autopsy
RSCoupe
Post by RSCoupe »
:woowoo:
Audilard
Post by Audilard »
Very, very nice Hank!! The color is growing on me! Now hurry up and come visit me in that thing!
Darin
1989 80 20vt
Derracuda
Post by Derracuda »
is that an ebay header?
Highlander
Post by Highlander »
Looks great man.
I can't wait to see her finished.
great work !! :D
Cheers,
Craig Cook.
Yeah, Darin, that is what I like to hear!! You will like it even more in person, and even more when it covers the whole car!!!!
Derek, hmm.. I think it is the header that the ebay headers were designed after, for this one was purchased out of Europe a couple of years ago before the current ebay special ever was. That said, it took extensive work to work.. The overall disign and placement is awesome, however, the flanges arnt... they suck actually, for they are warped like crazy, and arnt threaded on the inlet... So I cut them all off, welded my own flanges, and inside welded all of the original tube welds.. then all flanges were milled flat on my mill.. It is nice, pure stainless, and will support the turbos of my future(gt35r..)... the turbo inlet is so flat it will be ran without gaskets...
Highlander, Yeah, thanks.. Your IM is actually what inspired me!! So thanks for the kind words.. I cant wait to see your URQ!!!
Derracuda
Post by Derracuda »
aha, ok. well, the only reason i guessed it to be an ebay header, was the arch of the front primary with the welded seam in it. it didn't look like an 034 header, and it was polished, and has that one piece looking mounting flange. good luck with it :)
SteveAngry
Post by SteveAngry »
The engine looks tits. :)
Steve
probly because of those coils....
a_CQ
Post by a_CQ »
So is it running yet?? you said tomorrow. :P
Audilard
Post by Audilard »
Yeah, come on Hank! Drive it up here!
Darin
1989 80 20vt
RSCoupe
Post by RSCoupe »
WHAT'S TAKING SO LONG!!! :P
the presure is killing me........
Dang vr sensors.......
to be continued......
Audilard
Post by Audilard »
BOOOOO!!!!! BBBOOOOOOOOOOO!!!!!!! :wink:
Darin
1989 80 20vt
AudiSport4000
Post by AudiSport4000 »
Doh :P
Looks great so far, cant wait to hear of more progress 8)
1986 4kq Commemorative Design
2012 Jetta TDI
LOL, when I get done eating this enchelada, I am going to go get it started, and I ll show you darin!!!N!
AudiSport4000
Step away from the enchilada...
AND GO START YER CAR MANE!!!!11
:P 8)
2012 Jetta TDI
Nice Hank, I kinda like that alternator placement. Hmm.
owdlvr
Post by owdlvr »
Hank it's looking awesome man.
Definitely want to see photos for your PS tensioner. I'm currently running my 4kq pump on the 20v head with the "tighten it once a week" system :P
-Dave
PRA4WX
Post by PRA4WX »
audifreakjim wrote:Nice Hank, I kinda like that alternator placement. Hmm.
Funny you should mention this as i was noting and contemplating the alt relocate.....
Derracuda
Post by Derracuda »
that alt placement is just using 5kt pieces..
OK, I need help.. I have wasted a full day freaking around with the darn VR sensor, and I am about to kill somebody/something...
I can not get a steady 59 to save my freaking life.. At first I was getting really spastic numbers, that were not very consistent. One moment it would be 166 then drop to 66, then down to 45 to rise to 130 again.. I figured I had some sort of interference.. So I moved wires a little, and nothing.. Changed VR sensor, and nothing.. Used another flying lead my dad has for his URQ, and i got a somewhat consistent 68 signal. I figured I would then just run a new shielded wire, and see how that treated me.. So I did, all the crimps got soldered, and heat shrinked.. I thought for sure it would give it to me... Nothing, and now, I cant get a signal over 7 or so... I crank and it spits out 3s 4s or around there, meanwhile, the RPMs are around 8k on the computer, however I just get a random attempt at fire in one cylinder.. ARG :)
I dont get it.. and I am tired.. I am going to get me some icecream right now, and I know you guys are going to tell me what is crackin!! Important to note, that the air gap was messed with in every senario above.. Anywhere from .02 all the way up to .1 and nothing.. Oh and my shield is just conected to the third spot on the Audi VR sensor..
If you are pin swavy, I have the Number 7 pin on the IIC computer, connect to the middle slot on the plug, and the 14th to the first slot... obviously the shield is grounded to the shield or the third slot as mentioned above.......
HELP!!!! LOL
Jimmy, yeah, the alt location is sweet.. Wanna trade cars?? :P
Derracuda
Post by Derracuda »
weird on the sensor... i did a little tuning on a car equipped with a IIc that had a violent cut out sorta randomly... found out the VR sensor was just SITTING in the bracket, and it would jump out sometimes enough to lose the reading... then fall back in to read properly :P
Hey here are some pictures of that PS pump.....
Want more???.. IT is important to note that I started off with a 20v bracket, and it was pushed back using lots of spacers.. The Tention piece doubles up as one of those spacers..
OK, and now to work on my problem.... Here isa picture of my new bracket I made tonight for my VR sensor.. It sits down low, by the pan.. quite rigid, and away from things that may have been causing noise..
Derracuda
Post by Derracuda »
HA, you had it RIGHT by the alt? that might cause some sorta issue....
a_CQ
Post by a_CQ »
Wait a second - how is that sensor secured to the bracket?? It looks like its just hanging there???
