Re: Loxxrider's 200 20v Revver Project
You'd be looking at these
http://www.compturbo.com/products/ct5
HT Motorsport
Post by HT Motorsport »
The Borg Warner EFR's we are running in the mega V8 project are UBER impressive BTW. I don't know if they make them up to the size you are looking for but I would run them again in a heartbeat!
They don't unfortunately :( That would have been my top choice. At the moment, I'm leaning towards a a borg S476-ish thing, maybe with billet comp wheel. For some reason I'm finding that guys running the 4202 are running out of steam upwards of 35 psi and probably 100 lb/mim suggesting that the gtx comp wheel is just mismatched with its turbine wheel.
glibobbo21
Post by glibobbo21 »
Check out "extreme tuners' for billet wheel stuff too.
Jrod033
Post by Jrod033 »
loxxrider wrote:They don't unfortunately :( That would have been my top choice. At the moment, I'm leaning towards a a borg S476-ish thing, maybe with billet comp wheel. For some reason I'm finding that guys running the 4202 are running out of steam upwards of 35 psi and probably 100 lb/mim suggesting that the gtx comp wheel is just mismatched with its turbine wheel.
Can't go wrong with bw...great turbos...and funny thing I know a guy that has a brand new s476 t6 you should look into! Haha
Damn... they make some impressive stuff. E-mail sent (to them).
ha, Jrod, I'd be interested, but I need something T4 :/
123quattro
Post by 123quattro »
You might want to look into the T6 housing. T4 housing will cost you 100hp at the levels you are talking about.
Hmm, you sure? I believe the T4 housing is available with 1.10 AR and an 83mm (exducer) turbine. Borg's match-bot thing says that should easily flow what I need it to. I'm still not any good at reading the turbine plots, but I'm pretty sure it should be OK. Have a look for yourself:
http://www.turbodriven.com//performance ... sin=92044&
glibobbo21
loxxrider wrote:Damn... they make some impressive stuff. E-mail sent (to them).
Dunno how they work out but theyve made even bigger wheels for the large frame EFR's. Check out their fb. They update alot on there.
123quattro
loxxrider wrote:Hmm, you sure? I believe the T4 housing is available with 1.10 AR and an 83mm (exducer) turbine. Borg's match-bot thing says that should easily flow what I need it to.
My note wasn't based off compressor maps. It was from a friend that races a lot of Mustang 10.5 stuff in OH. He picked up 100hp changing turbine housing. A/R stayed the same.
I hear ya man, but that depends on so much more than just A/R. I believe you, I am just curious if it carries over to this particular application. Also, I wasn't referring to the compressor map, I'm referring to the turbine maps.
NASCAR clutch incoming :D
Uh.
Specify?
K thanks.
loxxrider wrote:NASCAR clutch incoming :D
Seriously? That's awesome! :dur:
Yep, Tilton 7.25" triple disk. They can be had for pretty good prices off of NASCAR cars used for one race.
Drive-ability is pure, absolute shit, but I don't mind. It kinda has to be that way to hold the POWAH!
loxxrider wrote:Yep, Tilton 7.25" triple disk. They can be had for pretty good prices off of NASCAR cars used for one race.
I approve. Dude, your car is going to be straight up NUTZOID. :P
loxxrider wrote:Drive-ability is pure, absolute shit, but I don't mind. It kinda has to be that way to hold the POWAH!
:lol: :lol:
Friggin awesome.
That is the plan, I sure hope so! :)
Kieron_UK_20V
Post by Kieron_UK_20V »
loxxrider wrote:by the way, does anyone want to buy an HX52 just rebuilt in the past 20 miles with v-band outlet already machined for 4" dp and flange modified to fit any T4 manifold? It is a nice 67mm (billet wheel) turbo! Make an offer I can't refuse 8)
What the spec on this Chris?
Im looking to import a Cheap HX52 to compliment my ABZ'd coupe.
I was going to buy a repairable core on ebay along with a rebuild kit and rebuild it myself over here, cant seem to find many cheap ones in the UK.
What would you be looking for, and any idea on shipping cost to uk?
Cheers.
Kieron.
not sure how much Chris wants for it, but shipping wise it sure as heck wont fit in a postal flat rate box. weight, I haven't put it on a scale but probably close too 50lbs, which is $150 to get to the UK.
Kieron_UK_20V
Ooooh, controversial. That sucks.
Kieron, Marc is right about the shipping. It wont be cheap. I'd like $250 out of the turbo itself.
They are something like 88lb/min I believe. 16 cm^2 exhaust housing.
Kieron_UK_20V
£250 delivered still sounds pretty good to me.
Have you got pics of the modified flange, save me flicking through all the pages.
I don't but it was done by Hank and you can't even tell it is modified. Fits nicely.
amd is the best
Post by amd is the best »
Need moar picz, vidz and updates :)
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Locked
