The PO said it was converted. The compressor didn't have the proper fitting on it so who knows. I'll probably just throw a new dryer in, replace all of the seals, and flush the whole thing out and then put some new oil and r134 in.
What do you mean by drain? Do you mean the oil or do you mean the r134, because all of the gas is already out of it. I'll probably just have someone service it I guess. I just don't have all of the necessary tools to get the job done. I can do all of the screens and seals though. Do you have any idea where they all are? I did the orifice tube already so thats one down.
jcarrick
Just got that same email, ha! Its soooo tempting..loxxrider wrote:OOoooo lookie what I just got in my e-mail...might have to just buy one of these if 034 doesn't hurry up with the darn manifolds!
Hello, we just receive the Audi T3 Turbo manifold if u are still interested i can send u a invoice through pay pal or you can purchase form my website http://www.strco.com
Thank you
Ishtiaq Din
Speedtrackracing
416 995 1968
jcarrick
Ya, if it's been properly converted no leakage should happen. Peroid. By drain I ment having the gas evacuated :-D Although if you do go through the system yourself, make sure you pull the compressor and allow it to properly drain all the nasty old oil out and fill up with the ester. Honestly whenever I did a full on conversion my boss always had us put on a new compressor, but I am sure it will be just fine without that kind of replacement. I was cheap on my Pathfinder and went with the old compressor, just threw in new seals/sceens and oil and the system has been great going on 3 years.
Anyways ... I have no idea where all the other screens are at on the audi system. I have only ever done GMs, my Pathfinder and a couple of Fords. SOO my knowlege is limited to that extent. I do know some systems may only run one screen. So if You have a bently ? It should show where they are all at.
I want it lol.
I'm back to finally being able to fully appreciate this car again. Everything working as one awesome combo. Got to use the brakes, the suspension, and the power tonight. Its crazy how huge of a difference the air temp makes in how quick the car is. I'm having fun at only 15psi. Injectors start to run out at more than that on the top end. Pretty lame. Man I wish it could have been right when it was cold out. I did some fine tuning of the cruising portion of the map tonight. Car cruises at 1.1 all the time. I'm going to see how far it can go before it doesn't like it. Fuel economy FTW!
I need a job to get this damned thing moving! I can't wait. Clutch needs to come soon after. Its been feeling pretty soft lately.
Oh and BTW, the 90 is a sure thing now. I leave Monday to pick it up
Yeah, the roadtrip fell through :( sad, but I'll have fun doing lots of other things this summer like Carlisle!!
Yes, the 90 is a 20v. I'm not sure what all I'd need to get it running, but I'm not even sure I want to. My wicked plan for it is an abz, nice suspension, and decent brakes. Thats about it! I think it would be a great car like that. I need some V8 in my life, thats all there is to it.
AudiSport4000
:woowoo:
1986 4kq Commemorative Design
2012 Jetta TDI
2012 Jetta TDI
Did you pay for it already? If not, have you considered Josh's 90 V8?loxxrider wrote:Yeah, the roadtrip fell through :( sad, but I'll have fun doing lots of other things this summer like Carlisle!!
Soon as I get it! I'm leaving in the morning tomorrow. I have to leave it up at school though because my parents don't want it here at the house while we are trying to sell it. Its good because that will let me focus on the 200 for the summer and then when I get up to school for the fall I'll be able to get to work on the 90 in my spare time
O2VW1.8T
LDC007
Something like this would be bass-ass, albeit quite expesive :bashtard:Justin517 wrote:I got mine running and driving for $700. The e34 is an amazingly well built car. They don't resist rust like a galvinized audi does but the e34 is better than the e28 or atleast that's what I've found. Living in Florida u prob don't have to worry about that anyway. Get one like mine with the big 6 m30b35. It's a 3.5L (well 3430 cc) with 208 up and 225 ft/lbs. I recently saw a dyno run of one... Stock except 19# mustang injectors (5% bigger or so) and 3" exh. Put down 190 wheel up and over 200 tq. A $225 chip will get you 43 more peak hp and like 30 more ft/lbs. They also take boost very well. Stock everything is good to about 400 whp. The e34 engime is 9:1 though... The e28 was 8:1... But thats still pretty turbo friendly. Oh and no timing belt either. There is a decent amount of aftermarket support too. See miller performance and turbocharging dynamics.loxxrider wrote:Hmm thats true. I do like RWD and have wanted to do a BMW for a while. I love E34's...the E34 V8's are terrible from what I hear though. Whatever it is it needs to be cheap. So that will dictate what it is. First thing that comes along thats cheap, I'm gettin it
http://fc01.deviantart.net/fs15/f/2007/ ... _roobi.jpg ... _roobi.jpg
Chris, I hear you on the AC; the temps in South Fl set a new record high this past week, hitting 93* but with the humidity index it felt a total scorcher :frustrated:
I myself am in the process of fixing the AC in my QSW, which after charging it last year, lost its freon in about a month's time. I believe I identified a leak due to a dried-out o-ring where the discharge hose connects to the condenser.
I have taken all but the evaporator out for cleaning and o-ringing it. Hopefully I put it back together this week and see how it goes.
I also need to tint the windows cause boy the sun here sure pierces through your skin especially when your AC is out!!
Hope you get your AC sorted out soon.
-Regards,
Louis
ahhaha the 200tq 1v has working a/c ahha not that we needed itWOMBAT wrote:I have the same exact problem with mine... I'm watching this closely
MMmmm just got back from a mothers day dive, then rope swing and the (on the water) snack shack, and then filets on the grill.
Thanks Louis, I'm driving the car to get the 90 tomorrow and then driving back home tuesday. Then Wednesday the car is going to be taken out of my hands to get the AC worked on :( I wish I had the tools to do it myself!
I bet they are going to be like, hey...you need a filter on your turbo...hey, you need a MAF sensor, hey you need a new windshield washer tank, hey you need a new steering rack, a new catalytic converter, a new blah blah blah Its going to be interesting. I wonder if they'll have trouble starting it up. Gotta give it some gas until I find some time to tweak the cold starts :-D
