Well the smaller treadstone is still efficient to 700+hp so it should be more than enough for you I'd think...unless you think you need to increase size that much? I don't feel like calculating the differences in air you'd need to move after this week lol. Anyway, my buddy made 610 or so on only 20psi on an intercooler very similar to the smaller Treadstone up there.
YESSSSSSSSSSSSS
I just scored a 12cm^2 housing
Muahahahah
and now I got the correct v-band and gasket included...go me! Now I wont have to wait until eternity for spool.
This puts intercooler purchase on hold until next month though.
If anyone wants to buy my corbeau to get the ball rolling let me know
Some things are difficult to calculate; to start the TC is working harder to move the same amount of air and there is ~18% less air touching the IC.loxxrider wrote:Well the smaller treadstone is still efficient to 700+hp so it should be more than enough for you I'd think...unless you think you need to increase size that much? I don't feel like calculating the differences in air you'd need to move after this week lol. Anyway, my buddy made 610 or so on only 20psi on an intercooler very similar to the smaller Treadstone up there.
Look at Jim Green's Intercooler _HUGE_.
GOOD LORD!!!!!
I feel like that thing can't possibly be using much of the upper cooling area. Either way, thats gigantic. Never seen one that big lol.
I dont get how there is ~18% less air "touching" the IC though...I see how there is less oxygen in the air...but not less air really. I'd think you'd have the same cooling. I guess I'm overlooking something.
I'd rather just run meth all the time than fit an IC that size...or air to water. MUCH easier.
123quattro
TheArchitect
Right, the mix is ~the same but the density is less. So your compressor has to work harder and your IC is less efficient.TheArchitect wrote:20.9% O2 of air to above 50,000 feet.123quattro wrote:The air is less dense, so it has less cooling capacity. It's not less oxygen, it's less everything.
Higher altitude means less moles of O2 per Meter^3, but not less oxygen per se.
ah ok I get it. Duh :bashtard:
glad I dont live in high altitudes
I got that idea from the mountain climbing shows where they are like yeah there is so much less oxygen in the air up here, you have to breathe harder, etc...
I took that to mean lower percent, not just less dense air in general. Should have thought about it a little. Sometimes my mind gets all jumbled like this. Especially after being bedridden sick all week. :(
jcarrick
Nope, too much extra bs for me at the moment! I like it this way anyway...kinda unique
That would be a good option. I just dont feel like messing with throttle relocation, etc., etc.
Speaking of which...my throttle cam is cracking. Time for a new TB methinks. (dont want to waste money on 034 billet cam thing when that money will buy me a bigger tb)
...though I may have to buy one anyway since I dont have machine shop access right now for an adapter flange :(
Progress is being made.
Got a 12cm^2 housing for the Holset in and fitted. Just need to weld the flapper shut when I install it. I even have a flange with a v-band provision but I'll probably just weld that right to the downpipe because I don't know the exact size of it and don't have a 2.5" one on hand to compare it to.
Its so much smaller than the 16cm^2 one that was on it though. If anyone wants the 16cm one please don't hesitate to contact me. This one is so nice...its hardly even got any surface rust on it. The 12cm one is nice too though. The 16cm would be perfect for a VRT or a M50 BMW motor or something.
Also, if anyone wants a Corbeau CR1 in black and gray suede mine is for sale. I just want extra money to finish this build up with!
and of course here are the adapters. Still haven't had the time to test fit yet. Looking forward to it. I just realized that I'll have 3 cars these wheels will work on lol. E36, the 200, and my mom's jetta since its 5x112. Her car is gold too so the gold centers would be perfect
oh and some partially green beer for St. Patty's day
I also forgot to add that the misfire issue has not been solved :(
Car is misfiring just as bad even with the wires and plugs now that I've really had some time to test it. Next step is D585 coils (the ones with the heat sinks on them). They are supposed to be some of the strongest in the GM line.
nuugen
But what do you consider "high" boost?? I thought you were running ~17psi :? Or did you turn up the wick recentlyloxxrider wrote:Yeah...me too. They have always worked great at high boost, etc.
Everyone says these cars just dont like anything but bosch plugs![]()
I would like to see if they hold up at higher boost levels---28-30 psi..Has anyone used them in that capacity? In my old setup I would spike 30 and drop to ~27, that was with the fdp's..I know they are not optimum for that level..I would like to hear other's experiences with the NGK at higher boost levels, as I do use them in my na cars and stock-ish turbo cars..javad apparently uses stock plugs for a 7a (F6DTC) in his high-boost motor...
jcarrick
I used NGK iridium's in my 1993 S4 running around 20 PSI and they started to misfire after about three months. They would boost up to about 15-16 and then it would just start falling on its face. So i put the F5PDOR's back in and it totally fixed the problem. From what i am learning in school with German cars bosch plugs are the only way to go. NGK's are great on Japanese stuff, but for german cars they dont work so great... dont ask me why :?
Chris,
What are you doing with the holset as far as the N75 goes??
Chris,
I was referring to my old 50 trim setup on my 1.8t. It was at about 22psi.nuugen wrote:But what do you consider "high" boost?? I thought you were running ~17psi :? Or did you turn up the wick recentlyloxxrider wrote:Yeah...me too. They have always worked great at high boost, etc.
I did run about 20 in the audi for a while tho lol.
Pretty sure plenty of people have used BKR7's in the high 20's with success.
I'm using an external wastegate with it so I'll just run the n75 in the wastegate line and thats about it. Same as stock just with a different wastegate.jcarrick wrote:Chris,
jcarrick
Well for one thing, I don't have the actuator for this housing, for two, I spent a lot of time convincing 034 to make me a manifold with ext wg provisions, and three because its just simple and more reliable in my opinion (when you have an old turbo like this at least).
I dont see why you'd have to put a hole in the housing for any reason???
LowlyOilBurner
nuugen
Well NGK's are fine, just not the Iridium...I tried the Iridium's too and they are fine for N/A, but not boosted..Same thing with the Platinum+4 Bosch, we found out pretty quickly not to use those in a forced induction engine when they first hit the market a few years ago! Most sites now have a disclaimer not to use them on boosted apps..jcarrick wrote:I used NGK iridium's in my 1993 S4 running around 20 PSI and they started to misfire after about three months. They would boost up to about 15-16 and then it would just start falling on its face. So i put the F5PDOR's back in and it totally fixed the problem. From what i am learning in school with German cars bosch plugs are the only way to go. NGK's are great on Japanese stuff, but for german cars they dont work so great... dont ask me why :?
gvr4
Iridium plugs are fine to use in a boosted car. NGK,Denso are two of the best ones. Iridium's come stock in a evo from the factory so they are not for N/A cars. Iridium's are what all the high hp dsm and evo guys run. Thats 900+whp cars.nuugen wrote:Well NGK's are fine, just not the Iridium...I tried the Iridium's too and they are fine for N/A, but not boosted..Same thing with the Platinum+4 Bosch, we found out pretty quickly not to use those in a forced induction engine when they first hit the market a few years ago! Most sites now have a disclaimer not to use them on boosted apps..jcarrick wrote:I used NGK iridium's in my 1993 S4 running around 20 PSI and they started to misfire after about three months. They would boost up to about 15-16 and then it would just start falling on its face. So i put the F5PDOR's back in and it totally fixed the problem. From what i am learning in school with German cars bosch plugs are the only way to go. NGK's are great on Japanese stuff, but for german cars they dont work so great... dont ask me why :?
My I ask what you are all gapping your plugs at. You may just need to knock the gap down to help with a misfire under boost. You could just be blowing the flame out.
Factory gap on my plugs are between 27-32. That works good up to around 20psi. After that I end up having to knock them down to around 18-22 for 30+psi.
