FS: $4,500 Casey's 200 20v
WOMBAT
Re: Casey's 200 20v: How to route Intake - My Solution
Post by WOMBAT »
super5 wrote:Just my 2cents., extand the end tank on top go with most direct angle too the TB from the back of the intercooler and put the blow off valve on the lower part of the tank of the intercooler.
I hear ya - I wanted to use the top outlet of the IC to TB route, but it required some sharp bends in the pipe to make it work due to the top of the center support and the hood release cable and I didn't want to start cutting that up and putting in hood pins. I'll rework the end tank so that the new outlet will be the most pronounced (instead of leaving it at the top).
I was thinking about the BOV on the IC too, but space is pretty tight up there.. Haven't given up yet though
put the bov flange right on ic/out endtank
fasterthenrs2
Re: Casey's 200 20v: Need your opinions! How to route Intak
Post by fasterthenrs2 »
loxxrider wrote:OK, to put it in more technical terms, head loss from a 90 degree bend is equal to:
HL=(Kl*V^2)/(2*g)
Where Kl is the loss coefficient and V is the average velocity of the flow.
For 1000 CFM, average velocity in the pipe is about 103.5 m/s so the head loss would then be ~163.9 meters. To get pressure drop from head loss, we have:
delta P = rho*g*Hl
where rho is the density of the fluid.
This gives us a pressure drop of 1606.5 Pa which is equal to 0.233 psi. So at least in theory, each elbow might account for about a quarter psi in pressure drop.
at what pressure
That equation is only governed by flow rate, not pressure. My other calculations were all done at 30 psi.
I forgot to say that I used a loss coefficient of .3, but depending on the quality of the bend, it can be closer to one which would make for a little over 3/4 psi drop.
fasterthenrs2
loxxrider wrote:That equation is only governed by flow rate, not pressure. My other calculations were all done at 30 psi.
Than have you thought about piping material, smooth vs cast, would really like to se flow differences on a flow bench, not like it really matters on a 5 cil, the head is the biggest pressure dropper.
super5
Post by super5 »
"I was thinking about the BOV on the IC too, but space is pretty tight up there.. Haven't given up yet though" See if there is room on the inlet side so the BV will release the hot comprased air and not heat soak IT since You are not recirculating the air.
the bov valve should be post ic as to not have to back flow to ic to relieve pressure
amd is the best
Re: Casey's 200 20v: Charge piping/Coilovers
Post by amd is the best »
WOMBAT wrote:Now mo-bettah. Can see my new (craigslist) tires - Conti pro-contact 245/45/R18
Can you provide me with the details on the helpers? Where'd you get the springs and the collar that sits between the springs?
Thanks homie!
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
does it run yet?
WOMBAT
Post by WOMBAT »
Thanks homie![/quote]
Woah sorry for the delay! I'll have to dig through my receipts to get the location. They're nothing specific, but I'll get you the details!
And a pic just to let you all know I'm still working!
Engine ready for alum weld
VEMS LCD mounted
Fan shroud done
Spaced motor downward 0.75" to clear the intake/ air filter from the hood
amd is the best
Looking great man!! Pretty neat idea with spacing the engine mounts down like that. My 1.8T IAT hits the hood.
I also like the mounting of your VEMS display. Probably much more visible then mine.
And you still need this: http://www.germanautoparts.com/Audi/200/Cooling/212/1 (LOL). Don't make me buy one and ship it to you as a gift.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
WOMBAT
Post by WOMBAT »
Hahaha ok ok
amd is the best
Haha! Look at the glorious engine bay and that grungy container, sorry I'm picky about that. Hell, I'd say change the master cylinder reservoir and hydraulic fluid reservoir too but those things are HUGE money. That'd also make me a hypocrite because mine look like poo too, lol.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Haha! Look at the glorious engine bay and that grungy container, sorry I'm picky about that. Hell, I'd say change the master cylinder reservoir and hydraulic fluid reservoir too but those things are HUGE money. That'd also make me a hypocrite because mine look like poo too, lol.[/quote]
Ha, same... Dunno if you saw mine @ carlisle but it looks terrible...lol. Completely out of place in the engine bay. A new one is on order.
At least on all of the Audis I've owned, the hydraulic fluid res is actually yellowish plastic, so not much you can do about that. New brake fluid res would look nice tho.
amd is the best
At least on all of the Audis I've owned, the hydraulic fluid res is actually yellowish plastic, so not much you can do about that. New brake fluid res would look nice tho.[/quote]
Oh I saw it. Gave it the epic stink eye too, lol. Change it, flush your coolant system and refill with G12+(+) and distilled water. The pink coolant makes the older models feel younger.
You are correct about the hydraulic res. Always yellow. I should paint that bish.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
You could replace the stock hydraulic res with something aluminium.
You are correct about the hydraulic res. Always yellow. I should paint that bish.[/quote]
Ed, is that the same epic stink eye we give GT cars without rods?
amd is the best
Don't hate. lol
I'll gladly entertain donations though.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Tomis
Post by Tomis »
You routing looks nearly perfect, shortest I ever seen, I would say use short radius cast elbow for intercooler outlet, then 45 deg bend , then you need only straight coupler and you are done with shortest interocooler piping ever.
ShavedQuattro wrote:Ed, is that the same epic stink eye we give GT cars without rods?
LOL ZINGGG :lol:
Oh I saw it. Gave it the epic stink eye too, lol. Change it, flush your coolant system and refill with G12+(+) and distilled water. The pink coolant makes the older models feel younger.[/quote]
Yeah yeah, I'm on it. The coolant has not even been in there more than ~8,000 miles anyways. The reservoir looks terrible though.
Oh and back on topic, Casey the car is looking great :D
WOMBAT
Post by WOMBAT »
Haha sometimes I love giving a day between checking posts :P
WOMBAT
Re: Casey's 200 20v: Back from the shop! Intake/Radiator do
Post by WOMBAT »
Back from the dead! Just some pics and minimal text. So close..
Rolled beads
Reworked end tank
Radiator bungs (one of 3)
IAT sensor, BOV, and throttle cable mounted.
Wastegate tied-in
2.5" V-Band off compressor to 2.5"-3.0" coupler
Nearly complete
JonathanL
Post by JonathanL »
Ahh that last pic is just :drool:
sexytime
