FS: $4,500 Casey's 200 20v
Ooo didn't know about that... I already have plans Sunday so I doubt I'll make it, but I'll have to stay up to date about meets in the area
I think I have a trigger for a 3b from when I parted the shell I had... I'll look tonight or tomorrow and let you know ASAP. I'm right in CT too so you would get it quick.
found it... 034 905 381?
LMK if you need it.
wow I just looked them up... $120 new!
id sell it for less than half that, lol.
LMK if you need it.
Hey Justin, thanks for the offer - I'll have to let you know as I'm putting it back together.
On another note - finally found some outer lips for the speedlines so that I could have them all be 8.5" wide and wouldn't need to have the crazy ass stretch and poke going on out back.
I'm thinkin i want to do it if i can afford it. Opinions?
(i know it'll be overwhelming for no mo stretch 8) )
yes, exactly. The back is not low and can't be because the wheels are ohhh about 1" outside of the fenders.... The new lips would put them flush just like the fronts
bimmerboy
bimmerboy wrote:I vote yes. I don't like stretch about as much as I don't like staggered on quattros(not that you had a choice).
heh yes, I am a victim! Couldn't pass up the wheels for the price so I made do with the staggered set up. But I'm pretty excited to not deal with it anymore
Plus, one of the rear lips has been welded! Just another reason...
Ok ladies and gents
I have this parts list put together for the engine build. I already have a headgasket so no need for that, but here's everything else. Just want to ask if any of you think I'm missing something.
I'm not putting the big turbo on yet (yet more money required to run it) but I'm building everything else as though it is on there. I will be trying to get the forward facing intake from Hank and the FMIC on and sorted as well but haven't included piping/couplers for that.
Main:
* Bearings
* ARP main studs
* Rear main seal
* front main seal
Rods:
* Bearings
* SCAT rods (comes with ARP hardware)
* Wrist pin retaining clips
Pistons:
* 5 sets of rings
Block:
* Oil pressure sensor (gave mine away to Dana )
Gaskets: I'm sure I'm missing some
* Oil Pan
* Oil filter unit - not sure of a real name for that one
* Valve Cover
* Intake (phenolic possible?)
* Throttle body
* Exhast Manifold
* All turbo - inlet/outlet exhaust, oil feed/return
* Wastegate to exhaust mani and outlet
* Audi standard 2.25" exhaust clamps - between cats and resonators.
Clutch: Do you work with Southbend? Looking for street use, I hope the car never sees a track. Ultimate power goal of 450awhp.
Misc:
* Exhaust manifold studs/nuts
* Power steering hose - reservoir to pump
* Timing belt kit
* Uprated motor and tranny mounts - street density
* Oil check valve
* Oil pump? Mine worked great, but again, 254k I assume I should replace
* Injector seals? - the pieces in the intake manifold
Input please :-D
Main:
* Bearings
* ARP main studs
* Rear main seal
* front main seal
Rods:
* Bearings
Pistons:
* 5 sets of rings
Block:
* Oil Pan
* Valve Cover
* Throttle body
* Exhast Manifold
Misc:
* Timing belt kit
* Oil check valve
Input please :-D
oldsklaudidub
oldsklaudidub
oldsklaudidub wrote:WOMBAT wrote:hmm yes good advice, thank you!
College student=counting pennies. Don't you remember it wasn't too long ago?
hah.... i'm STILL counting pennies.... maybe even worse than while in school.
oldsklaudidub
Re: Casey's 200 20v: Need your Input! Parts list...
How's the penny counting going?
wow from the dead - I was just reading through my thread since I'm having 200 withdrawls...
well, I have all the motor parts sitting in a box next to my car in VT; doesn't do me any good being in NYC. Good news is that I just took a job with IBM in VT and will be near my car once again so I can do something with those parts.
I'm thinking I need to either make my rear wheels more narrow (8.5" like the front) or make the fronts wider (10.5" to match the rear) and then find some flares to make use of some 285's all around....
8.5" would be the sensible solution, plus I think I like the look of the smaller dish on the 8.5 with the 200. Not to mention it'd be a shame to cut into the body on this car.
oldsklaudidub
Your a funny guy, your not in NYC, your just north of White Plains. Ill take you to the east side of the Bronx, then you will be in the city. lol
I think its time you get the motor built and get her back to running. Its been too long.
Re: Casey's 200 20v: Moving to VT
it's easier to say nyc then explain it... plus im in Manhattan at least once a week.
screw this place.
It has been time to build that motor since it was taken apart in September of 2009. It's going to remain a slow process...
screw this place.
oldsklaudidub
Im worried about all of the rubber lines on the car etc, since its been sitting over a year. Brakes are probably seized too.
Was the plan to includes VEMS?
oldsklaudidub wrote:Im worried about all of the rubber lines on the car etc, since its been sitting over a year. Brakes are probably seized too.
it has been living it a nice heated garage, I'm not too worried. Right along with the V8 that I sold back to Cort 8)
and yes, VEMS
oldsklaudidub
Do I spy a Ferrari?
That is a very nice garage. I particularly like the loft. the leather couch is a must.
yea, a ferrari (MR2 turbo) and an experimental aircraft
oldsklaudidub
ehh close enough, mid engine rear engine blah blah blah, they look the same, one just costs a little more than the other. Now an airplane in the garage, thats just so James Bond lmao.
apavlov13
Did Cort buy the V8 back so he can leave it parked in garage again? LOL
Mange3586
Where in VT are you going to be?
hahaahha WP is not nyc haha
but vt is def better than either
