FS: $4,500 Casey's 200 20v
Are you going to paint the bottom lip?
In my opinion thats what really sets that look off!
3B'dB3
Post by 3B'dB3 »
I found another pic of your car from WF!
http://www.vwvortex.com/gallery/gallery ... ellaneous#
second from the left. :-D
Good to hear you got your hands on a bumper thats the correct color!
its gonna be the best thing you ever did! no looking back man! 8)
WOMBAT
Post by WOMBAT »
loxxrider wrote:Are you going to paint the bottom lip?
you bet! going to either cut the lower grill out too or paint it black so that it doesn't stand out like it does now..... I also want to get a V8 rear bumper mounted up to balance the skirting front to back and I'll paint the lower part of that as well. Lots to be done!
And yea, it's definitely staying pearl white!
And it makes me giddy seeing pictures of my car that I didn't take for once - thanks for the link! :D
3B'dB3
Post by 3B'dB3 »
It would get my excited too man!
ive been thinking about it...paint matched DTM V8 Spoiler?
Attachment ( 17861 ) : Carlisle2007_025_sized.jpg
WOMBAT
Post by WOMBAT »
yea, was thinking about it today. Leaning away from it - but they do look good
3B'dB3
Post by 3B'dB3 »
doesnt hurt my feelings at all, Im not sure how it would change the look.
kinda batmobile-ish almost..
nuugen
Post by nuugen »
WOMBAT wrote:Nothing really to report today, just took the license plate bracket off and cleaned up the bumper.........on hold 'till the fender mounting brackets show up.
More pics because there are never enough!
Hawt Casey!! I have always loved the look of the V8 bump with the 200 headlights/grille..
Only thing I would change is cut off that tow hook..If you really want one retrofit the screw-in type from the V8..
And I am trying to come up with a side-skirt solution--the rockers on a V8 are deeper to match the deeper bumpers, and once you hang them on 1 two hun' the side view becomes awkward...
nuugen
Post by nuugen »
I have another q? WHY did Audi put those little "tits" on the bottom of the molding :? :frustrated: I am going to grind mine off(since I have many sets of them) to make it sit flush on top of the bumps..
awesome...that is EXACTLY what I have in mind for mine.
Didn't get a chance to go to the junkyard today, but I did call and they said I could have it for $38 lol Ill just have to remember to take the lights, struts, and fender clip things with me I guess?
derrish_vulf
Post by derrish_vulf »
man v8 bumps with 200 headlights/grille look SO perfect!!!
I found a place local that has both front and rears, and they also buy from where i work so i get a nice discount. Im thinking about picking em up now!!
WOMBAT
Post by WOMBAT »
nuugen wrote:
WOMBAT wrote:Hawt Casey!! I have always loved the look of the V8 bump with the 200 headlights/grille..
I was thinking about painting this tow hook black and removing the lower grill to make my own, but I would certainly prefer the screw-in type hook. As for side skirts, the car will be hurting for some especially if I get the rear bumper on there too.
I have another q? WHY did Audi put those little "tits" on the bottom of the molding Confused Frustrated I am going to grind mine off(since I have many sets of them) to make it sit flush on top of the bumps..
just because they wanted them to get stuck on the V8 bumper if anyone tried to do the swap :P
WOMBAT
Post by WOMBAT »
man. that's dirt cheap, go for it! and yea, pick that stuff up too! Also pick up the plugs for the fogs and signals in the bumper for a cleaner install
88Quattro
Post by 88Quattro »
dude that front end looks TOP DAWG DOOOO ITTTT !!!!
WOMBAT
Post by WOMBAT »
Quick update - bumper brackets showed up before lunch today so I checked them quick - won't be a bolt up jobbie, so stay tuned for some mish-mash of V8 and 200 bumper brackets put together
bimmerboy
Post by bimmerboy »
And here comes a raise in v8 bumper prices :) But does anyone know how the bumper would match up with non flared typ 44s? (aka us poor 20vt folks)
WOMBAT
Post by WOMBAT »
we'll see what happens with the home-made bracketry (new word) but the edges of the bumper can be pulled all the way in so that it's uniform with the chrome trim by the wheel well
all pictures thus far are w/o the sides of the bumper attached in any way
nuugen
Post by nuugen »
Yes the bottom of the V8 fenders differs from the 200's in a way that impedes the use of the V8 side brackets..
WOMBAT
Post by WOMBAT »
Made some progress with fender brackets. A quick trial of the V8 bracket made it clear that it could not be used as it was. The first thing that made sense to me was to cut the bracket in half, so out came the saws-all. Here's the 200 vs V8 bumper mounting types.
to mount these half brackets I slid them onto the bumper, put the bumper on the car and marked with painters tape where the mount was located. I also looked between the chrome trim with a flashlight to get an idea as to where the mount was to go vertically.
Once I had idea of where it needed to go, I marked a line above the mount where I thought was the correct location and then put the mount and bumper back on the car to check the mount's position relative to the mark I made.
When I was confident in the location, I drilled 2 7/64"pilot holes for some sheet metal screws and attached the brackets.
(Driver's side)
Passenger Side
The following pics show the fitment.
I then spent a stupid amount of time trying to bolt the bumper onto the car with no success. I was able to drill all 6 holes in the struts in just the wrong spot so that none of them line up :frustrated: this again helps me with the clean install though because I'll finally look into putting the V8 strut end on the 200 strut which may allow me to have the bumper in the right spot and still have functioning struts.
If all else fails, I'll break out the steel and make some rigid struts. At some point I'll start looking into ways of getting the corners of the bumper to pull in, perhaps using the existing slots near the top corners of the bumper. Stay tuned....
noriceforyou
Post by noriceforyou »
Oh man soooo nice! Bloody cars should have come like that from the factory :)
derrish_vulf
WOW!! Lookin awesome man!!
BloodRed
Post by BloodRed »
Alright....I've added a V8 bumper and flared fenders to my to do list.....In the new "spend more on the body than I paid for the car" section...
Just sexy. :drool:
WOMBAT
Post by WOMBAT »
Nearly complete on this project! Today I decided to scrap the V8 bumper struts since everything about making them fit was ghetto at best. I decided with the welcomed influence of the 'geek community to make some struts out of the 200 and V8 pieces. Here's what we have:
First I cut off the mounting brackets on the 200 struts and cleaned them up
Next up was cutting the V8 struts. The 200 struts as they stand are too short to just weld the V8 bracket up. Before taking the V8 struts and bumper off of the car, I measured the distance between the frame rail and the end of the V8 bracket. I found that I needed 5/8" additional strut added onto the 200 strut, so I made my cut with 5/8" strut still attached.
Here's the result - no welder here, so I'll have to do it at work tomorrow unless there's someone in the Utica, NY area that can help 8)
Till then, I need to lengthen the turn signal wires so that they reach their new location. Once the struts are welded up, I should be good to go other than pulling the corners by the wheel well inward for a better finished product.
derrish_vulf
Next up, REAR V8 bumper :P
WOMBAT
Post by WOMBAT »
truth.
siena
Post by siena »
Personally, to make it flow better, I'd be inclined to use V8 fenders, and make the angle match the 200 headlamps, even if it means grafting the 200 fender tips to the V8 ones.
At least, the V8 fender flares will be a 100% match for the bumper then...
