Wheeljack
Re: I took the BLUE Pill. It's in (most people feel that)
Post by Wheeljack »
I would bet 99% of the time it actually functions as an engine mount warmer...
http://brydon-eng.com
a_CQ
Post by a_CQ »
If you're going to use MR2 pump, I would suggest keeping it within the wheel base lines. It will help wih distribution but you don't want any weights really pass the wheelbase in either direction. Mine was in the trunk, and it was fine but it's not ideal. My next step was to move it underneath the car, under rear seat base. Would have to mount it very securely - it's not the lightest piece. I would also add simple in-line cooler. Summit has some in different lengths that can be easily attached under the car along one of the lines. In a street car, it would be too loud in the trunk, IMO. Granted you have a tank and back seat as isolators, but still, I'd shy away from mounting it inside. As Jimmy said, a toggle switch is a must for when you need ignition on but car is not running - it woud kill a battery fast. Other than that, it's a very reliable system IMO. I had zero issues with mine, aside from occasional fluid boil - I didn't have that cooler installed yet.
Mercedes A klass is a much nicer/smaller piece but very expensive, and obviously harder to source in the states. Mini Cooper used them too but they had a lot of issues so I would stay away from those.
Polar moments are bad. :)
I just hate pulling 75 amps ALL the time when the thing is on. That is a ton of current that is having to be generated by an alternator, even if you are going strait.
a_CQ
Post by a_CQ »
I always turned mine off on the highway. Elsewhere, it ran 100%. You could wire in the load reduction if you wanted, diagrams are out there, or have maybe 2-3 speeds setup.
Yeah, stay away from anything Mini! I don't think they pull 75 amps all the time, that is the worst case, under load trying to turn my 275's standing still.
quattro v1.0
Post by quattro v1.0 »
elaw wrote:Or use something like this: http://www.ebay.com/itm/12-40V-100A-120 ... 0357609275
Well I kinda like that controller. In theory you could adjust your level of assist as well as turn it all the way off if I am reading it correctly.
Om the bright side that 07k comes with a kickin' alternator ;o]
quattro v1.0
Wizard-of-OD wrote:Looking good and yes that is an oil cooled engine mount
Technically its just a hydraulic engine mount. Cars have had them for a long time. Hank just has to go all-in when he builds something.
In reality that block takes the place of the original water-cooled oil cooler. This side of the engine block is lacking any significant engine mounting bosses due to it's orientation in the rest of the FWD cars. This is serving two purposes, it's providing much needed mounting points for the engine mount itself as well as remote mounting the oil cooler and filter somewhere in all that extra real estate where the side mount radiator mess was extracted from.
elaw
Post by elaw »
quattro v1.0 wrote:[/quote]
Well I kinda like that controller. In theory you could adjust your level of assist as well as turn it all the way off if I am reading it correctly.[/quote]
I'm not sure how well that would work.
Changing pump flow rate does two things: it alters the level of assist, and alters how quickly the pump can provide assist. As in, for the system to work fluid must be pumped into a cylinder, and if the flow rate is low enough it won't be able to keep up. So with the pump running at low flow, you could get a loss of assist if you tried to move the wheel too quickly.
quattro v1.0
Well you DID suggest it. If what I need is a switch than I don't need a a controller I guess.
zarati
Post by zarati »
Some of the older Audi Rally Cars (I think, or maybe it was IMSA) used a traditional hydraulic pump but driven by a belt off the rear drive shaft. Was mounted where the rear seats usually are. If someone was creative, you could do a custom mount on the rear subframe or where the OEM Fuel pump / Battery box is and drive a pump off the rear driveshaft there. It would be susceptible to contamination and moisture might be a problem but its a thought.
pkw
Post by pkw »
zarati wrote:Some of the older Audi Rally Cars (I think, or maybe it was IMSA) used a traditional hydraulic pump but driven by a belt off the rear drive shaft. Was mounted where the rear seats usually are. If someone was creative, you could do a custom mount on the rear subframe or where the OEM Fuel pump / Battery box is and drive a pump off the rear driveshaft there. It would be susceptible to contamination and moisture might be a problem but its a thought.
wasn't that an alternator? i can not picture a hyd pump in that configuration working well for low speed steering.
What would be trick is to put the alternator on the rear of the engine off that vac pump drive, run an electric water pump and electric PS pump, and forget about accessories on the front :)
a_CQ
Post by a_CQ »
Peter, it was both. They used special diff housing to accomodate mounting provisions.
Awesome pictures Peter. Thanks
I'd be tempted to bolt the MR2 pump to the diff just to get it out of the way.
quattro v1.0
Doesn't the mr2 pump have a built-in reservoir? If so I'd think the orientation of the pump kinda matters.
I have seen Jimmy's setup but I can't quite remember the details.
PRA4WX
Post by PRA4WX »
I have seen Jimmy's setup but I can't quite remember the details.[/quote]
I believe maybe the later ones do. Earlier do not.
Looks like one version has a res and one does not (from a quick google). Also found this http://www.dsmtuners.com/forums/article ... -pump.html" onclick="window.open(this.href);return false; about using the MR2 steering ECU and sensor.
zarati
Post by zarati »
a_CQ wrote:Image
:thanks:
I like the CV Cups in that photo. Are they only 3-bolt? They look like a custom setup.
Nice pics. I knew I had seen the PS Pump driven off the Driveshaft but couldn't recall exactly how it was setup.
glibobbo21
Post by glibobbo21 »
Next hurdle is the stupid serp belt relay deal. Stupid dual belted ac comp!
I think I have a solution there using a vr6 PS pump instead of an AC pump to do the jack shaft. You will just need all the tension and rollers from the oem setup. Now that I am back from vacation, this swap is getting finished.
:woowoo:
Looking forward to seeing it!
quattro v1.0
ShavedQuattro wrote: Now that I am back from vacation, this swap is getting finished.
Who takes a vacation...
Toph
Post by Toph »
Who takes a vacation...[/quote]
Rich people.
Looks like it's progressing nicely! Jim showed me a pic of all the shiny bits involved so far - love it.
Oh, and I'll be flying into Vegas on February 13th, spending the night, driving down on Thursday to Palm Desert for my friend's wedding, and back to Vegas for the 17th through the 20th. Hopefully you folks are around, it'd be great to see you three again.
...but that won't be a vacation, it's different... :lol:
90 Coupe Quattro - 3b + 01e
87 4000 - future trail rig
