mounty
Re: Taco's 4KTQ 20vt Swap: Project Red Baron - RALLY BASKET!
lol. hmm. wonder if i could do the same.... sure it isnt actually knocking/ pre detonating?
Yeah its not knocking. I had several people ride in it an they all agreed that no knocking is present. Especially at 14psi and 91-93 oct
mounty
i wonder if mine is being tripped due to my exhaust... factory down pipe and nothing else...
My exhaust is factory 5ktq downpipe. It opens up to a 3". Have you tried differnt sensors?
mounty
Honestly no. Its been too damn cold. Haha. Havent driven it much either.
Got my summer fix list together:
URq HD Bilsteins (Im not liking my t44 shock setup)
034 Strut Mounts
3" Mandrel Bent DP
More Port work on EM followed by welding a brace between runners, followed by milling
All exhaust components ceramic coated including turbo hotside
Volvo K24
Redo all exhaust studs with SS and copper locking nuts
Ceramic Coat IM
New passenger and driver tie rods (with powdercoating)
Jergen Reman Rack and Pinion
New PS Lines
Powdercoat front and rear sway bars
Fix WG flexi coupler
Front CQ springs in rear and level out car
034 Strut Mounts
3" Mandrel Bent DP
Volvo K24
Ceramic Coat IM
New PS Lines
I like this list. Carry on.
were you planning on my volvo k24?
I think there is something missing from that list. Possibly the most expensive part(s).
I was just going to say EFI to cover all the parts associated with it
scubadave wrote:were you planning on my volvo k24?
Was hoping so.
I do plan to go VEMS but that fix list is more important right now. I need a 100% solid car to support solid power
SOB!!! I think the driver window reg died or something. The cable is all screwed up inside, its 20 degrees outside, and its half way down...WTF. The window reg wants to move the window but due to the cable being all F'D up, it wont go anywhere. Does that mean the reg went out? Someone get me one!
AudiSport4000
Pro tip....dont roll down the windows in freezing temps in older Audi's
Call up and get you one, yo!
1986 4kq Commemorative Design
2012 Jetta TDI
2012 Jetta TDI
hahaha yup haha its toast
Alright so I got a regulator coming from my trusty source as soon as the weather isnt below freezing where he is. In the mean time I am going to attempt to replace and fix the cable.....perhaps I'll come up with a repair kit and sell it lol
Ok, for a gigiganormous amount of $2.50, I got 10ft of 1/16" cable, 4 cable stops, and 2 center crimps, I am going to attempt to repair the window reg tonight
Let us know how it turns out. Im sure there are more than a few people with the same problem.
Me, I need the stud mounts for the motor. :(
AngryTaco wrote:Ok, for a gigiganormous amount of $2.50, I got 10ft of 1/16" cable, 4 cable stops, and 2 center crimps, I am going to attempt to repair the window reg tonight
That is how the driver's window on my Urq was repaired.....works well!! Actually works better than the other since everything was cleaned and lubed while apart. Good luck.
DE80q wrote:Let us know how it turns out. Im sure there are more than a few people with the same problem.
tap the out w a hammer and use bolts jeez
Weekend fix list:
Heater Control Assembly (replace my home made one with OEM)
Tear out passenger seat and Driver
CLEAN, Armorall, vacuum, etc
Rip up carpet around ebrake and weld the body mount back together
CLEAN and Shampoo Carpet
Interior is dirty and a disgrace right now.
What about the regulator? xD
Fixed that last night with a complete working unit. Still gonna repair mine.
mounty
Wanna clean mine too?
Send it over lol.
Arrrg Ive been getting code 2113 recently. Probably explains the hot start problems. Good thing Ive hot an extra distributor
