Ed's 1991 CQ: Progress!
Re: Ed's 1991 CQ
Good to know! I was not sure how much they could flex.
Ed's 1991 CQ
Still shopping for stuff but it is getting to be crunch time.
Hoping to pick my Holset this week.
Still need exhaust manifold, downpipe, wastegate, BOV, misc lines and charge air pipes.
Headed to Philly for two weeks then it will be crunch time for BBQ2!!!
Re: Ed's 1991 CQ
It is getting crunch time....Hank has been planting bad ideas in my head about a short block and rods and other evils.
Darin
1989 80 20vt
1989 80 20vt
Ed's 1991 CQ
Resist!Audilard wrote:It is getting crunch time....Hank has been planting bad ideas in my head about a short block and rods and other evils.
His used mani has put bad thoughts in my head }: - )
Re: Ed's 1991 CQ
Resistance is futile. The force is strong with this one.
Ed's 1991 CQ
:hankwaveshand: "This is not the engine you want to run"cbrydon wrote:Resistance is futile. The force is strong with this one.
Quattro v1.0
Re: Ed's 1991 CQ
Hank leave these guys alone! We want these projects wrapping up in time to make it to Vegas NEXT MONTHAudilard wrote:It is getting crunch time....Hank has been planting bad ideas in my head about a short block and rods and other evils.
Re: Ed's 1991 CQ
The reality is is that it does need rods with the 30R and 25psi. Rigjt now I hit 20 psi and 340whp. The 30r comes on so strong rods are coming through the block one of these days if I'm not careful.
Darin
1989 80 20vt
1989 80 20vt
Re: Ed's 1991 CQ
Yes indeed the force is strong with this one, but it has not always been so. Early in his training, before he was allowed to wield the power of the lightsaber called TIG, he was more concerned with paint color, dvd, tunes and other low priority items. It got to the point that these diversions were given priority over a working 2nd gear, 100k timing belt, brakes, suspension, and even.....are you ready....HORSE POWER!!cbrydon wrote:Resistance is futile. The force is strong with this one.
May he live long and wield the force with power, integrity, and compassion for those of us with less than 200hp.
Re: Ed's 1991 CQ
So was that the Dark Side or the other side?
Re: Ed's 1991 CQ
As you know, the force can be used for either good or bad. It all depends on ones perspective I suppose. There is nothing wrong with nice VS function. Personally I think a well executed form of function is where it's at, but there are those that would put luxury out front. I think that when it gets to the point that a hybrid is good because it serves the purpose of getting you there and there was no enjoyment in the process.......That is the dark side!!
Re: Ed's 1991 CQ
We've turned Ed's project thread into a "force" discussion.quattro87 wrote:As you know, the force can be used for either good or bad. It all depends on ones perspective I suppose. There is nothing wrong with nice VS function. Personally I think a well executed form of function is where it's at, but there are those that would put luxury out front. I think that when it gets to the point that a hybrid is good because it serves the purpose of getting you there and there was no enjoyment in the process.......That is the dark side!!
Is it done yet Ed??
Darin
1989 80 20vt
1989 80 20vt
Ed's 1991 CQ
Its not going to be done till it starts and it's not starting till 8/19 at the earliest :p
- Sent from my iPhone using Tapatalk
H1C7aTASAP!
Thanks Chris!
This should be interesting....
mhorsfield
Re: Ed's 1991 CQ
:stupid: i like where this is going
Re: H1C7aTASAP!
Is this picture backwards?Mcstiff wrote:Thanks Chris!
Darin
1989 80 20vt
1989 80 20vt
Re: Ed's 1991 CQ
AFAIK, the picture is unmodified. The parts in the pic are not sitting the way you'd install them.
HeartlessNomad12
Re: Ed's 1991 CQ
Just bolting that to your 034 7AT??
Re: Ed's 1991 CQ
I am getting that whole assembly from Loxrider (Chris) and bolting it to the 7a in my 1991, with a few other parts. Not shooting for the moon so the rods and pistons should be fine.
HeartlessNomad12
Re: Ed's 1991 CQ
running the chipped ECU from 034 that came with the kit??
peterpeterson
Re: Ed's 1991 CQ
whats your HP goal?
Re: Ed's 1991 CQ
I think 300awhp is reasonable with E85. I have a feeling that I could find the rod limit before the piston limit but I'd rather not kill a good engine (at least until I have another built).
