Re: Ben's AAN 4kq - Progress Continues - Sept 2nd or bust
Thanks guys. :)
AudiSport4000
Post by AudiSport4000 »
Looks great! Excellent work :D
1986 4kq Commemorative Design
2012 Jetta TDI
AudiSport4000 wrote:Looks great! Excellent work :D
Thanks man!!!
So this weekend's update is pretty good, I bled the clutch, fixed my shift rod (YET AGAIN!), reinstalled and cleaned the back seat and front passenger seat, modified and installed my AAN valve cover, worked out how I'm going to run the electric water pump and tore into the wiring harness. I did LOTS AND LOTS of wiring this weekend on it, integrating the URS4 harness has been somewhat of a challenge because of all the extra stuff it has that I don't need. So I figure at this point I am 75% done with the wiring. :)
PICS!
JonathanL
Post by JonathanL »
That exhaust looks wicked. Do want hear it behind that holset ..
Pics= me jealous
JonathanL wrote:That exhaust looks wicked. Do want hear it behind that holset ..
Pics= me jealous
Thanks man! :)
Re: Ben's H1C/K26 AAN 4kq - Progress Continues-Sept 2nd or b
Looking great. Almost looks complete!
I'll be very disappointez if this does not make bbq3
@ Loxx, Getting damn near there man! I'm very excite!
ShavedQuattro wrote:I'll be very disappointez if this does not make bbq3
I'm going to do my best man!!! :D
I know the feeling!! Looks awesome BEN
ShavedQuattro wrote:I know the feeling!! Looks awesome BEN
Thanks Hank!! :D
So today was an excellent day, mainly because the I received a box full of awesome in the mail....
AAAAAnd I was stuck waiting on parts for all the cars I was working on today so I went out an did some install work on it :)
I gotta say this EFIexpress stuff is really top notch stuff...
:thumbsup:
40v4kq
Post by 40v4kq »
Is the giant hole at the back of the turbo the QSV?
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
are those new tb cable rubbers?
40v4kq wrote:Is the giant hole at the back of the turbo the QSV?
HAHA I wish!!! I actually can't run a QSV with this turbo. If I was running a turbo with a t3 split on the hot side and a t3 non-split on the manifold side I could. I am saving the QSV stuff for my next build on this car.
@ my2000apb - Ya, kind-of, we had a random box of these things laying around in the shop. I needed to figure out how to keep the cable from rubbing the IM. So I am temporarily using at least the one closest to the tb. I may keep the other one.
SO I need some help guys, I am stumped on this one... for some reason my Harmonic balancer is hitting the oil pump and timing belt cover when I tighten down the crank pulley bolt, and for the life of me I cannot figure out why... bear in mind this is the original Serp-pulley/balancer that came with this engine, so I can't figure out what I am missing. :( Please give me any ideas or thoughts you have about his issue, I need to figure this out asap. :)
How things are sitting at the moment...
Re: Ben's H1C/K26 AAN 4kq - I needz help - Gurus come forth!
Ok, so I figured it out with help from Marc. I was informed I may have the balancer that requires the washer that goes between the balencer and the cog. Turns out, I do. I found the $100 washer in my parts bag, installed it and now am back in business!!! :) I am so glad I took a few minutes, cleared my mind, got help and ate. Progress is now resuming.
40v4kq
Re: Ben's H1C/K26 AAN 4kq - Figured it out, progress resumes
Post by 40v4kq »
Glad to hear. Keep on truckin.
Dan
1984 Ur quattro
glibobbo21
Post by glibobbo21 »
Ive done a bunch of URS timing belts and there doesnt seem to be a rhyme or reason to what engines they put them in...the washer that is
glibobbo21 wrote:there doesnt seem to be a rhyme or reason to what engines they put them in...the washer that is
That is so retarded. I wasted over half the day on this problem. :dur:
glibobbo21
You dont know, til you know.
At least it was only 1/2 the day and you didn't have to spend another $100 and wait for the part...
ringbearer wrote:At least it was only 1/2 the day and you didn't have to spend another $100 and wait for the part...
SOOOO TRUE! More than likely I would have bought the washer, installed it and in a week found the old one. Now that would have been a bummer! :) I'm just glad I have been such a pack rat with my Audi parts.
looks awesome Ben, I've never checked the thread before. 4ks are just so awesome. do you have an eta?
quattro87
Post by quattro87 »
Yes he does......BBQ in October. :-) That, of course is a few weeks after initial startup! He will be traveling a couple thousand miles with it so will need to have some of the bugs worked out beforehand. Good progress!!
