HT Motorsport
cuatrokoop
AudiSport4000
Awesome
1986 4kq Commemorative Design
2012 Jetta TDI
2012 Jetta TDI
Toxcheap
Toxcheap
Thanks! The B3 bumper was already as far foward as it would go so it mated up pretty well. It could stand to go foward another 3/8", but it works for now. I put a little notch in it for the fender flares and then made a bracket that bolts to the back of the fender to hold the rear of the bumper up. I hear ya on the b4 rear flares, I'd love to do it, but that's opening a much to large can of worms.
Yea, so I seem to have gotten sucked into buying a big screen yesterday with that moneySeStone wrote::woowoo:
So when do those fancy new flares get filled out?
Sam
I'm not sure what the plan is yet. I'll probably convert the front to B4 struts and hubs for more offset when the 01E transmission goes in since it has the big output flanges and I could then easily use B4 driveshafts and it should all mate up. Then I need to make the decision to go 5 bolt or not. For the short term I'm just going to toss some spacers on and some 225 rubber next time i need new tires.
The ultimate goal is to have B4 rear fenders, and some Porsche Twists on it. I love those wheels. BTW, Tox, you suck for having some!
Toxcheap
Highlander
Keep the stock radiator shroud. The one from my coupe fits really nicely and my temps always stay down below normal. I have an extra if you need it.audifreakjim wrote:Mercedes turbo diesel cooler in front of the radiator. My setup isn't large enough for hot track days, I plan on putting a massive oil cooler on the passenger side this summer, and an 034 aluminum radiator that's well-shrouded.
Darin
1989 80 20vt
1989 80 20vt
Darin, I think you gave the advice...but I'd add a lower duct out of a thick corrugated plastic material, such as that found in realty signs. Unless you're running a bellypan, there's a big hole down there.
That said, I heard some rave stuff about the sheetmal ducting done to Christian's Coupe.
Sam
Sam
Sam Stone
As of tonight I'm off the E85 crack pipe :( It's for good reason though, I'm finally going to make the ACNA Steamboat event this year :-D I'd burn through a tank just driving up there so I figured I better get back on pump gas and work on some fine tuning since I haven't run 91 on these larger injectors yet.
