jbrentd's 2nd Chance CQ - Getting Closer
Re: jbrentd's 2nd Chance CQ - Merging the 7A & 3B Harnesses
Postby jbrentd » Sun Feb 28, 2021 8:01 pm
There used to be a guy on the S2Forum who made carbon fiber door sills. Does anyone know if those are still an option?
Spent some time today to continue cleaning the engine bay. Gonna hit it with a fresh coat of pearl before the 3B goes in.
jbrentd
Postby Afterthought » Sun Feb 28, 2021 8:29 pm
Looks excellent , not easy to clean all that grime out
Postby jbrentd » Sat Mar 06, 2021 4:36 pm
Afterthought wrote:Looks excellent , not easy to clean all that grime out
Thanks! The white shows everything.
Decided to make a run to a local junkyard that had a cabriolet, just to see if there was anything worth grabbing. Glad I did because it had a good belly pan and a few other things I brought home. Didn’t really need the B4 hood stuff, but figured it was worth the effort since it was “all you can fit on a wheel barrel for $80” day.
I should have grabbed the window regulators, brake booster and few other things.
jbrentd
Postby jbrentd » Fri Mar 19, 2021 3:10 pm
Engine bay touch up is done. Man, that was a tone of work...do not want to do that again.
jbrentd
Postby Afterthought » Sat Mar 20, 2021 1:07 am
Dude I still can’t get over how good a deal you got on all those parts . I would be in heaven if I found pearl b4 front end and fenders.
Engine bay looks great. When you get the engine in this will really be worth all the effort . Will look amazing .
Only Issue is now you have to take everything to this level of cleanliness .
Postby jbrentd » Sat Mar 20, 2021 6:38 am
Afterthought wrote:Dude I still can’t get over how good a deal you got on all those parts . I would be in heaven if I found pearl b4 front end and fenders.
I know. Need to check with them to see how often they have that deal. I’d like to go back and get a few more things. I’ve already sold the hood conversion parts.
Afterthought wrote:Engine bay looks great. When you get the engine in this will really be worth all the effort . Will look amazing .
Thanks. That’s a tough one. I’ve tried to clean most everything I’ve touched, but the underside has not received the same treatment. I think I might break out the power washer again before I se it on the ground. It worked pretty well on the wheel wells.
jbrentd
Postby morris400 » Sun Mar 21, 2021 7:38 pm
Looking good buddy. Its coming along.
2016 VW GTI DSG Daily Driver
2001 B5 S4 Stg 3- (Gone)
morris400
Postby jbrentd » Sun Apr 04, 2021 3:35 pm
Got some time today to put some parts back on. Was good to get some garage therapy time.
jbrentd
Postby Afterthought » Sun Apr 04, 2021 5:28 pm
Engine bay looks so good .
If you have any plans to change anything on the booster or steering rack do it now , ha
Postby jbrentd » Sun Apr 04, 2021 9:49 pm
Afterthought wrote:Engine bay looks so good .
Thanks. Yeah, I’ve been really tempted to convert to vacuum assist, but I had Dave Kase rebuild my bomb last year and it’s been working well (knock on wood).
jbrentd
Postby FFF » Fri Apr 09, 2021 11:30 pm
Engine bay looks great! What’s next?
Sent from my iPad using Tapatalk Pro
FFF
Postby jbrentd » Sat Apr 10, 2021 3:46 pm
FFF wrote:Engine bay looks great! What’s next?
Thanks. Next is to reassemble everything. I’m really pushing to have it running by early Summer.
Today, I bled the new master cylinder, connected the hardlines, ABS pump, booster, rack, stabilizer, and tie rods. Also spent way too long fumbling with the battery cable grommet.
I’m trying to figure out where to cut the fuel tank vent line that goes to the evap canister. I am switching to an evap canister that goes in the fender. I think I might just cut it down low where it turns up in to the engine bay and run a rubber fuel hose to the evap.
jbrentd
Postby FFF » Sun Apr 11, 2021 12:48 am
Be awesome if you get it on the road this summer.
It's been so long since I pulled my car apart I'd have to go back through pictures to even recall the setup!
FFF
Postby jbrentd » Sun Apr 11, 2021 6:43 pm
FFF wrote:Be awesome if you get it on the road this summer.
I have to do that regularly myself. Would be lost sometimes without them.
jbrentd
Postby jbrentd » Sat Apr 17, 2021 3:24 pm
More stuff making its way back on today. 3B wiring harness and what’s left of the 7A wiring harness, coil, bomb, washer tank, hydraulic fluid reservoir, new hood release cable.
jbrentd
Postby FFF » Sun Apr 18, 2021 9:34 am
Coming together nicely.
FFF
Postby jbrentd » Sun Apr 18, 2021 4:13 pm
FFF wrote:Coming together nicely.
Thanks Forrest.
Today, I made a bracket for and mounted my fan resistor pack. Also got most of the fan wiring done. Does anyone know which post on the 500W fan motor is positive?
I also attempted to make a set of rubber flaps that go in the fender well around the tie rods. I think they turned out okay.
jbrentd
Postby jbrentd » Sat Apr 24, 2021 10:35 am
Anybody see an issue with using this for my chassis ground on my battery relocation? It’s an m12 to m10 stud screwed in to captive nut on the frame rail for where the old procon10 bracket be used to be. I would shorten the m10 side so that it doesn’t stick out so far.
jbrentd
Postby jbrentd » Sat Apr 24, 2021 2:01 pm
I added a small length of negative cable to a post I can use for charging/jumping.
I think all I have left on the power/ground front is to make a new ground wire for the bell housing and to change the positive terminal on the 4 awg wire to the starter.
jbrentd
Postby themagellan » Sat Apr 24, 2021 5:10 pm
Everything looks amazing - great idea with the jump post, now that you added it hope you never need to use it :)
Postby jbrentd » Sat Apr 24, 2021 6:53 pm
themagellan wrote:Everything looks amazing - great idea with the jump post, now that you added it hope you never need to use it :)
Thanks. I am trying hard to keep it clean and tidy. I like the idea of being able to jump it (if needed) from the front or rear and not be worried about which way it’s parked in the garage.
jbrentd
Postby jbrentd » Tue Aug 10, 2021 10:33 am
Progress has been SLOOOWW!! Pretty typical for me in the Summer, with the heat and lots to do around the house. I’ve also started the process of building a dedicated detached garage/shop. I hope to break ground later this month. But here are a few small updates…
Test fitted some new wheels. TSW Revos, 4x108, 17x7 et45. I plan to paint or powder coat them and use a 10mm, 15mm or 20mm spacer.
I recently picked up a Kamei armrest. Think I might paint it grey and recover with grey vinyl or leather.
Lastly, I’ve been kicking myself for not doing a better job of labeling this mess. But I’m almost done and just have a couple non engine harness plugs to identify.
jbrentd
Postby jbrentd » Mon Aug 16, 2021 8:09 am
Although I was able to get the auxiliary relay panel mounted up, I don’t think I’ll be able to get the knee bolster on with all the guts hanging out below. :-). Not sure if I can poke them in or will have to unplug everything and go about it a different way.
Did some test fitting of my 17x8 et35 Hockenheim’s with some 15mm spacers that I bought for the Revo’s. Might be a tad too aggressive.
Also got the transmission and front subframe in yesterday, but failed to take a picture.
jbrentd
Postby Afterthought » Fri Aug 20, 2021 10:50 am
that wiring looks great and man the engine bay looks so clean , and the wheel wells .
I don’t know if you’re going stock or what exactly you’re doing for turbo and exhaust but the only one thing to check is downpipe clearance with that stud.
Postby jbrentd » Fri Aug 20, 2021 5:19 pm
Afterthought wrote:that wiring looks great and man the engine bay looks so clean , and the wheel wells .
Thanks! I was planning to trim that post down after I get the transmission ground cable built and connected. To start with, it’ll be the stock turbo, EM, and a modified 3B down pipe.
jbrentd
PreviousNext
Return to Projects
Users browsing this forum: No registered users and 3 guests
cron
