Adapting Coil on Plug to 3B Valve Cover
Postby jretal » Sat Aug 15, 2020 9:20 pm
Hey all,
I'm planning on running 3b intake bits on the AAN I'm putting in my 4000.
Has anyone modded the valve cover to run coil on plug type coils (vs. GM, etc.)?? I've seen folks adapt the 7a valve covers, but not totally positive on what's involved.
Welcome any/all thoughts! I have a few spare coils left from my RS4, and there looks to be some machining required to open up the hole, but any explanations/experience is appreciated!
Thanks! Once I get a few more things lined up, I'll actually update my build thread!
jretal
Re: Adapting Coil on Plug to 3B Valve Cover
Postby PRY4SNO » Sun Aug 16, 2020 8:32 am
Not sure what valve cover you're using, but on my AANs I just installed the coils and harness then ran them as is with no issues.
Postby varia » Sun Aug 16, 2020 10:10 am
PRY4SNO wrote:Not sure what valve cover you're using, but on my AANs I just installed the coils and harness then ran them as is with no issues.
aan valve cover wont clear the 3b intake.
¯\_(ツ)_/¯
project 2226
varia
Postby jretal » Sun Aug 16, 2020 1:19 pm
I'm looking at adapting coil on plug to a 3B valve cover!
Currently the holes are too small, so just wasn't sure what all was involved, or if anyone had done it before.
jretal
Postby varia » Mon Aug 17, 2020 10:42 am
on 7A, yes, many times. on 3B, nope :(
¯\_(ツ)_/¯
project 2226
varia
Postby jretal » Mon Aug 17, 2020 4:08 pm
varia wrote:on 7A, yes, many times. on 3B, nope :(
Yeah - that's what I've seen too. I'd assume it'd be something similar, but obviously looking for 1st or at least 2nd hand experience!
jretal
Return to General
Who is online
Users browsing this forum: No registered users and 12 guests
cron
