URS6 + 4.2T Getting Them Breakin Miles
Re: URS6 + 4.2T Getting Them Breakin Miles
Postby lorge1989 » Tue Jun 16, 2020 9:19 am
Add an additional ground when trying to start. Its funny how easy it is to forget a ground which can prevent starting.
1988 Audi 90Q 1.8T 20v megasquirt'd and Holset'd
1994 Audi 90Q ABZ
2003 VW Jetta TDI
1978 GMC High Sierra
http://dubsinthebuff.com
lorge1989
Postby jolio1994 » Wed Jun 17, 2020 4:11 pm
Pulled the starter and bench tested voltage drop. It was going all the way down to 4v. So, it's at the shop being rebuild at the moment.
Tacked up the Intercooler piping and the wastegate dump which I'll weld up tomorrow, and just kinda put the front end on...
You'd never know!
Image2020-06-17_04-58-49 by Joel Francisco
jolio1994
Postby quattrobros » Thu Jun 18, 2020 12:59 am
Cant believe thats the same car that had the turbo out the hood. Looks great!
quattrobros
Postby mrdeye » Thu Jun 18, 2020 6:00 pm
Proper!! :beer: :thumbsup:
Mr.
Previous cars:
mrdeye
Postby jolio1994 » Wed Jun 24, 2020 11:40 pm
Had an issue with my MSD starter and took it up the street to be rebuilt. They gave me a completely different core and put the nose from my old on onto it, and told me it'd be fine..
Image20200622_130127 by Joel Francisco
Image20200622_150641 by Joel Francisco
Well, now my ring gear is toast. Engine came back out and I took the tone ring off, but Clutchmasters doesn't sell only the tone ring so that'll be shipping out to them to be rebuilt. Ordered another MSD starter from Summit in the meantime and reinstalled the engine so I can address a few issues I found.
-Radiator outlet hose too close to alternator pulley, will be redoing.
-Making all the rear coolant lines out of 3/4" aluminum instead of rubber since there will be a lot of heat back there.
-Fabricating the 3" turboback
The crossover pipe is mighty close to the coolant temp sensor in the rear as well as the crank sensor. I'll see if theres enough room to relocate it to go under the car instead of behind the engine as well although I'd hate to remake it.
But yea... this sucks. I dont have the balls to goto the rebuild shop yet and tell them what happened not that I'm sure they'd care
jolio1994
Postby PRY4SNO » Fri Jun 26, 2020 9:43 am
That shop should certainly stand behind their word. That sucks all the same.
When you're redoing the coolant lines in 3/4" aluminum, what kind of connections are you using?
Previous
Return to Projects
Who is online
Users browsing this forum: Google [Bot] and 31 guests
