Page 14 of 22
Re: 1984 Ur-q with 20vt and 6-speed aka Shannon, she drove!!
Posted: Thu Jun 23, 2011 5:27 am
by ralleyquattro
Marc,
Couple of more questions, why does the battery voltage say 9V, where can I correct that?
Also, why does Lambda target jump so much, in the table it's at 1 in all of the boxes?
Thank you!
Posted: Thu Jun 23, 2011 7:27 am
Keep at'r Martin, it'll come together. Dad and I know the feeling - after putting his stroker together the intake cam was off a tooth, making the car feel like it was naturally aspirated! Now we're chasing what we think is a boost leak, as the car hits 22-25psi and won't go any higher. But we've ruled a lot of things out and just have to keep going.
Take a break, have a beer, cool down, and try something else. :)
Posted: Thu Jun 23, 2011 7:42 am
by ralleyquattro
Yes, the 90 quattro gave me excuse to rip it's engine out for the tdi swap, so I might start that this weekend, it will be a stress relief to get into that one... anyone need a low mile 2.8 V6? Would hate to see it go to the scrapper!
Posted: Thu Jun 23, 2011 7:47 am
by Highlander
Hang in there Martin.....................400 hp is just round the corner
Cheers,
Craig
Posted: Thu Jun 23, 2011 7:48 am
by quattroman
most insurance companys will email you scan of the insurance paper that you can use to get your sticker renewed. btdt..in ontario.
Posted: Thu Jun 23, 2011 8:25 am
by ralleyquattro
I may try a different office, the one I went to did not accept a letter, they want the pink slip because it's harder to forge.. or some shite like that.
Cheers
Posted: Thu Jun 23, 2011 8:32 am
by 1wheelpeel
ralleyquattro wrote:to top it off one son has trepthroat and the other one had high feaver all night... I am so deflated!
I'm sorry to hear about your luck Martin. The last time my daughter had strep throat, they gave her amoxicillin for it. We found out she was allergic to the drug after being on it for 6 days. Her allergic reaction to amoxicillin was horrible and lasted over 3 days. I know what you mean by being exhausted. I really do hope your luck changes for the better soon.
Posted: Thu Jun 23, 2011 9:09 am
by Warner
ralleyquattro wrote:Yes, the 90 quattro gave me excuse to rip it's engine out for the tdi swap, so I might start that this weekend, it will be a stress relief to get into that one... anyone need a low mile 2.8 V6? Would hate to see it go to the scrapper!
I'm interested. I htink one of my headgaskets is going. I need a rad also. Do you need it for the tdi swap or are you going side mount?
Posted: Thu Jun 23, 2011 9:15 am
by ralleyquattro
Sold!
Giong to 2.5tdi I5. Poor engine's been sitting in my garage for 2 years now :slap:
Posted: Thu Jun 23, 2011 9:22 am
by my2000apb
ralleyquattro wrote:Sold!
:o
Posted: Thu Jun 23, 2011 9:32 am
by Audiurq
Hang in there!
cheers, Mike
p.s. WIll you be running VEMS on your tdi :wink:
Posted: Thu Jun 23, 2011 9:45 am
by ralleyquattro
Double VEMS on that puppy.. leave no room for error. ;)
Posted: Thu Jun 23, 2011 10:14 am
by quattro87
Hang in there Martin. It gets better. The kids will get better, then they get older, and will eventually even move out leaving you with nothing but the old Audis to get frustrated with. :wink: I feel your pain, but you will get it.
Posted: Thu Jun 23, 2011 10:21 am
by ralleyquattro
Thanks for all the supportive comments, I shall double my efforts.
I see that I can calibrate the ECU voltage and that should help the injector opening time.
The only other question is why is the Lambda target moving? Moving targets are harder to hit you know.. ;)
Hope to have some more time tonight to tinker with this.
Posted: Thu Jun 23, 2011 11:06 am
Can't run VEMS on TDI. I know cuz I already asked Marc :)
I'm putting a 1.9tdi in a 1996 Europa S6. Kind of opposite of you - big car small engine vs. small car big engine.
Posted: Thu Jun 23, 2011 11:13 am
by ralleyquattro
What happened to Mike's green S6?
Posted: Thu Jun 23, 2011 6:09 pm
by ralleyquattro
Finally some good news, the kids are feeling better, loaded with anti-biotics...
And I was able to calibrate the battery voltage.
Wow.. what a difference, can't believe it was that easy! Runs 100% better, holds Lambda without problem, smooth idle.. I feel like jumping for joy! :-)
If it wasn't for the rain or the insurance restriction I should be driving it to work tomorrow! :roll:
For now I am going for a spin while it's still nice out!
Good night all!
Cheers
Posted: Thu Jun 23, 2011 6:17 pm
by glibobbo21
hows the linkage, reverse?
Posted: Thu Jun 23, 2011 6:21 pm
by ralleyquattro
No issues there, all well (for now).
Posted: Thu Jun 23, 2011 7:00 pm
by Audiurq
cooooool :woowoo:
a lot of hard work, well done!
next step tdi with 30lbs of boost :D
Posted: Fri Jun 24, 2011 3:24 am
by ralleyquattro
Took her for a short spin last night, roads were a bit wet but no matter.
Pulls nicely and the sound fromt he intake, NICE! Didn't get on the throttle that much and kept rpm below 6k, the VEMS display cycles too much between screen to be able to see anything worth while, anyone know how to configure so it stays in the main one? That way I can get on it and keep an eye on the stats.
Mr. Cook... I need an exhaust, can you see the people at Tartan Motorsports and give them a swift kick? ;)
I still have some issues with throttle touching the hood, need to do some surgery.
Did I mention how much I like these cars?
Cheers
Posted: Fri Jun 24, 2011 4:00 am
by Highlander
Awesome Martin,
Road trips here we come.
Nice 3" exhaust from Tartan Motorsports coming up !!!!
Congratulations.
Summer drive.......let's all get together.
Cheers,
Craig
Posted: Fri Jun 24, 2011 4:17 am
by glibobbo21
034 mounts? Theyre def a bit taller. I doubt theyll sag much over time though.
Posted: Fri Jun 24, 2011 4:23 am
by ralleyquattro
Yep, 034 mounts. I'll see if I can space them lower a bit... even 1/4" will help.
Posted: Fri Jun 24, 2011 4:44 am
by Highlander
Does that mean she's getting washed, striped, and door rings ?
Cheers,
Craig
