Not too much to update, I've been driving it a lot with no issues.
Forget if I ever posted an engine bay shot after it was running.
IMG_20161119_135533 by
Vex Art, on Flickr
The hockey puck mounts caused unbearable NVH, especially above 2500rpms. I'm not sure how I survived 3000 miles down and back to Vegas. I did order some of the orange practice pucks as suggested, but those felt even stiffer so they got returned. Decided to try B5 mounts which I had been thinking of doing years ago. Ordered some B5 RS4 (non-hydrualic) mounts and they work great installed upside down. Might be able to install them rightside up if you ground out enough of the B4 mount, but I couldn't be bothered. Did have to trim some off the thread of the driver's side bottom to prevent it from hitting the subframe, but that was easy. SOOO much better. No more body numbing vibrations at idle and ear bleeding drone at highway speeds. Exhaust still has a small amount of drone between 2-2500 rpm, but not bad.
Modified B4 mount (cut and pried out the OEM hydraulic mount; hole drilled in center):
IMG_20161119_131605 by
Vex Art, on Flickr
B5 RS4 mount installed upside down:
IMG_20161119_131615 by
Vex Art, on Flickr
Also swapped to all black tails for now:
IMG_20161105_125741 by
Vex Art, on Flickr
