V8 and 5000 Torsion rear diff
What is the Diff between these two diffs?
Re: V8 and 5000 Torsion rear diff
V8 is torsen, 5k is open/lockable
V8 is 4.11:1, 5kq is 4.11:1, 5ktq is 3.89:1
I'm sure there is more, but those are two differences off the top of my head
Awesome! So how about a v8 rear diff and a stock 4000 trans O1A I think they are. I know the gear set is the same but can the torsion rear diff work with the locker front?
the 4000 comes with an 016 transmission. You can run a locker front and torsen rear. I'd much rather run a torsen center and torsen rear.
To do that you'd need a transmission from a 200 20vt which is a 4.11 ratio 016 with a torsen center differential. Torsen center, torsen rear. And better highway gear ratios in the 200 20v transmission than the 4000.
Yeah.
Yeah.
v8q dif is also much stronger which is why it's desirable to high horsepower urS guys
im not sure about thisAngryTaco wrote:v8q dif is also much stronger which is why it's desirable to high horsepower urS guys
Pretty sure I've seen many more broken V8 diffs than anything else.AngryTaco wrote:v8q dif is also much stronger which is why it's desirable to high horsepower urS guys
lolwatAngryTaco wrote:v8q dif is also much stronger which is why it's desirable to high horsepower urS guys
youz trollin
why do I always see v8q difs going like mad for like $400 then?
The urS guys eat them up
Or am I wrong? Seriously correct my ignorance if I am
Moderate power delivery through and out of a turn is better with a torsen rear. High power launches break torsens. It depends on intended use.
Rob
ohhhhhh ok. That whats I thought honestly. I coulda swore I saw other people say it was stronger. *shrugs* Guess that means my v8q will destroy an urS in the corners right?
Lift a wheel during a turn with lotsa power and sticky tires and bye bye diff. They dont like power or shock.
- ringbearer
They are a good match for the 20v crew
ringbearer wrote:They are a good match for the 20v crew
This is what I see
123quattro
What they said above. Put a V8q diff in something that can spin the tires and they explode. I wanted one for my 200 20v until I saw what Sam Stone did to his.
