Justin (bangetek) 1996 UrS6
JustinB_20vt
Re: Justin (bangetek) 1996 UrS6
Thanks for the comments guys!
So with VE's in the high 90's I was able to get a good warm idle last night with a req_fuel of 4.1 but i still have a random misfire from fouled plugs and f me FR5DTC, F5DPOR and F6DTC are non stock everywhere i go locally so i will have to clean them up.
Ed, I looked over the paperwork that came with the injectors i didn't see anything regarding ramp up time? Regarding the voltage compensation are you using the simple method or have you put in the values for each voltage as supplied on the sheet?
Justin aka banget3k
JustinB_20vt
Thanks Ed! Turned out to be the injector rampup that was causing the issues around idle... back to my calculated req_fuel now and my VE table looks "normal" only some minor acceleration enrichment and partial throttle tweaks to make
Justin aka banget3k
JustinB_20vt
Pretty simple.. it's a 4" cobra head intake with a K&N conical air filter ... i added a PCV hose using a 10AN (i think) thread to hose barb.. i drilled the fitting and inserted a wire to act as a captive in case the nut insde ever decides to backout. PCV hose is an old heater core outlet hosePRY4SNO wrote:Welding procedures aside, your engine bay looks fantastic.
Very interested in details on your turbo inlet pipe.
Justin aka banget3k
And vids!
JustinB_20vt
Whelp car is now tuned pretty darn good for street gas.. planing the switch to e85 in the next few weeks and then get it on a dyno with some tuning help.
This happened yesterday ...
Spent a ton of time stripping, priming, painting, and clear coating these so im glad they fit ... they came awfully close to my BBS's but they clear 'sigh'
Justin aka banget3k
What bracket and eBrake?
JustinB_20vt
Apikol brake bracket, still working on the ebrake setup and will be designing a bracket for the ipsco calipers and have it water-jetted out.
Justin aka banget3k
JustinB_20vt
Whelp made the switch to E85 a few weeks back! need a tuning guru or two to look over a log and lemme know how things look (4th gear run).... no hard timing changes at this point will do that on the dyno in a few weeks. I am thinking i need more acceleration enrichment or a longer period?
- v3.3_n001842-2014.02.04-18.56.39_jb.vemslog
- (93 KiB) Downloaded 1637 times
Justin aka banget3k
bet your EGTs will drop by over 150c (and you'll get about +50whp) if you add +8 degrees of timing from the 102kpa row on up. Do it now, thank me later
Meant to look over this last night but I forgot. Will do in a bit! 8 degrees eh Marc? That's a lot. This is from the base map? I took a timing OUT of my tune (but I was on .63)... gonna have to have a look now.
I'm interested to see your spool on the gtx71 vs my cast 30r
chaloux wrote:Meant to look over this last night but I forgot. Will do in a bit! 8 degrees eh Marc? That's a lot. This is from the base map? I took a timing OUT of my tune (but I was on .63)... gonna have to have a look now.
to be clear, this is for E85. and yes, I generally find E85 likes to be around +8 or so vs pump gas.
Oh didn't realize E85. Then YES!
That's pretty sweet. I have a 3rd gear log here so not apples to apples unfortunately but at peak torque (ish) you're getting an extra 4psi on me. I imagine that in 4th we'd be pretty well dead even as it sits. BUT, that timing increase is going to help A LOT so I would expect your spool to improve.
Fatten up fuelling from 3500-4200. It should help spool a little and give you moar torques. The cells circled in the attachment.
- fuel cells
- justin fatten.jpg (215.78 KiB) Viewed 42869 times
JustinB_20vt
Thanks for the suggestions. any explanation of why i need a fatter tune under vacuum? It was really flat when tuned for 91ron however i did go back to marks suggested injector settings... maybe just getting into partial fuel cut down low? should i even be worried...
Justin aka banget3k
Well it should need more fuel everywhere... is it running bad? Misfire or fouling plugs? If not then that's just what it needs i guess.
And hey! Where are the vids!?
JustinB_20vt
Hmm guess it just needs a bit more down low
replaced the plugs over the weekend and no signs of rich/lean or detonation. I gaped the replacements too narrow (hard starting) so i will have to address that.. other than that car runs great
Few videos when i was running 91ron
Justin aka banget3k
Dutchbroracer
Awesome car man! Sounds pretty healthy. Love those wheels.
JustinB_20vt
thanks! are those 18" rx's or rg's?Dutchbroracer wrote:Awesome car man! Sounds pretty healthy. Love those wheels.
Justin aka banget3k
Dutchbroracer
Mine? I wish they were 18's. They are 17x8 BBS RC's. I like the look of 18's more though, even on a ol type 44.JustinB_20vt wrote:thanks! are those 18" rx's or rg's?Dutchbroracer wrote:Awesome car man! Sounds pretty healthy. Love those wheels.
Sweet car man! I also have questions about the intake setup, as my hardware is similar (even down to the heater outlet PCV hose...). Did you ever move the oil cooler back to the driver side like you mentioned on the 1st page? Im still usimg the stock oil cooler which makes thi gs tight on that side of the bay. Can you get the headlight cover off with out removing the intake?
Rob
JustinB_20vt
No my cooler is still on that side however i clears better than the stock one would due to the angle its mounted. The K&N filter i am using is oval tapered so it helps a bit with clearing the cross member from the frame to the fender. Yes i have to remove the intake to get the cover off but that only takes a minute.roortube wrote:Sweet car man! I also have questions about the intake setup, as my hardware is similar (even down to the heater outlet PCV hose...). Did you ever move the oil cooler back to the driver side like you mentioned on the 1st page? Im still usimg the stock oil cooler which makes thi gs tight on that side of the bay. Can you get the headlight cover off with out removing the intake?
Justin aka banget3k
JustinB_20vt
Posted over on QW but it feels real good to not have to use wheel chocks
Justin aka banget3k
Sweet. Where did you source the mechanical?
Edit: never mind, my reading comprehension needed help
Looks sweet!
Looks sweet!
JustinB_20vt
Running a bit better
popped a boost hose off tonight and there was oil everywhere so im gonna have to watch the turbo compressor seals
Justin aka banget3k
