4 FOX SNAKES - Ross' 20vt 4kq
Clem86
Re: Matt's 87 4ktq -
Post by Clem86 »
Depends on the car and if the owner wash it when spring is coming I guess. My B3 is in the salt and snow for more than 20 years, and it's not that rusty, only 2/3 points on top of a wheel + some down the doors.
jretal
Post by jretal »
these cars look good w/ the racks on top ;)
Clem86
Post by Clem86 »
Hahaha .. very subtile =)
Lol at those tires Justin. That is epic.
So martin informed me that 88 90q front single piece struts will bolt up and have wider caliper mounting so I can use rs2 etc brackets and my bbk. So the hunt begins... I put in an inquiry with Shokan as well. Anyone here parting an 88 90q?
Or does someone wanna make me some brackets? Haha. If all the kit needs is brackets, SOMEONE has got to want to make some :-) I'll have to play around next time I have my wheels off.
bradyzq
Post by bradyzq »
jretal wrote:these cars look good w/ the racks on top ;)
In drip rails we trust.
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
AudiSport4000
Post by AudiSport4000 »
FYI I have an 88 90q that has 2 piece front struts. I even have an early model car with 1 piece rears. Maybe the 80q's used single piece fronts? I just wasnt aware of any 90q's that came with single fronts, but as usual, I am probably wrong :)
1986 4kq Commemorative Design
2012 Jetta TDI
bradyzq wrote: In drip rails we trust.
LOL TRUTH!
Stoked right now, Jason @ VEMS let me know my ecu is good to go and I'm hoping it arrives by the end of the week.
So here's some food for thought - I had major issues because the insulating sheet at the top of the case was compromised (by me). It fried 3 ignition drivers and two injection fets. I'm wondering if things getting shorted out or doubled voltage etc could have caused my engine woes. At this point I have no idea what was going on in there. Regardless I'm going to make foxing sure that my timing is perfect.
Good man! I want to see some actual driving videos of this beast!
I am happy for two reasons. One, your car will be alive soon! Two, I finally get the title of this thread. Just had to say it out loud a few times ;)
chaloux wrote: Regardless I'm going to make foxing sure that my timing is perfect.
And now I finally understand the name.
jretal
Post by jretal »
how did you compromise the insulating sheet?
jretal wrote:how did you compromise the insulating sheet?
When sliding the ecu back in the drivers scraped along it which I couldn't see /tell. Bummer.
And Jim and Phil - LOL. Certainly suits my ownership experience so far.
Ok, I feel like a moron, I still don't get the name. LOL
Looks like I got a vanity plate for my birthday - 4FOXSN8X
Also, I said this to one of my sisters the other day:
UrSobsessed
Post by UrSobsessed »
Ouch! How easy is it for this to happen? Having opened mine a couple of times, I'd hate to have damaged something! Perhaps I'll put a little note in the N80 provision write up warning of this...
I think it was when sliding the main board back in. The fets /drivers scraped it. OR it could have been when sliding the insulating/holding bars in but I have a feeling it was the drivers on the board. Just bent up too much, or if you put it in the slot above where it's supposed to go.
85oceanic wrote:Ok, I feel like a moron, I still don't get the name. LOL
LOL Ben, say it fast... ferFOX snakes. Sounds a little like a certain saying used immediately after being hurt or frustrated etc.
HAHAHAA ok I get it. LOLOL I was thinking how does Four foxes = snakes??
WOMBAT
Post by WOMBAT »
chaloux wrote:Looks like I got a vanity plate for my birthday - 4FOXSN8X
This is AWESOME
ralleyquattro
Post by ralleyquattro »
AudiSport4000 wrote:FYI I have an 88 90q that has 2 piece front struts. I even have an early model car with 1 piece rears. Maybe the 80q's used single piece fronts? I just wasnt aware of any 90q's that came with single fronts, but as usual, I am probably wrong :)
It was very early 90q, I had a set till I threw them out last year, the only difference between them and 4kq and provision for ABS sensor and larger spacing for the caliper brackets. They also had the hubs that used nut on the CV as opposed to later which used a bolt.
HTH
90q struts1.JPG (90.61 KiB) Viewed 26808 times
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
Well I buttoned up a bunch of things today - injector wiring, headlight fixing (wtf it was barely mounted!), air filter install, cleaned up and painted some do-dads, mounted the new coolant reservoir, and got the boost/oil pressure gauges in (still have to wire both). Had the day off so I made use of it! It also appears that my ECU may be here tomorrow, or at the latest Monday. Tomorrow would be SIIIICK!
I know it's a small piece but I'm still kinda proud of it - fabricated my own gauge mount for the vent. Used some thin-ish mild steel and went to town with some basic tools - grinder, die grinder, hacksaw, and a punch kit my dad uses for getting big conductor into boxes. Finally, some plasti-dip and this is what I ended up with! It's not machine-perfect and I kinda like it that way. At least it fits tight and won't fall out and doesn't look like a cheap plastic shit hackjob.
It's official, you will freeze your balls off in the winter. LOL Looks good man!
no winter driving fo dis car! that's geo duty, until it turns into rustdust
ERMAGERRRRR VEMS has arrived! I feel... So... Happpyyyy :drunk:
