Custom front strut housings for UrS4/UrS6 coilovers...
Postby EDIGREG » Wed Mar 20, 2013 8:50 pm
There has been some demand since I built my coilovers, so I am making these modified strut housings available.
The modifications include a lower seat machined from 4130 hardened steel, removal of OE lower spring perches, and lowering of the steering arm to make room for a 5" coil sleeve and restore factory tie rod geometry. I can also clearance the edges of the steering arms and clock the arms inwards if you prefer (only necessary if running tires wider than 255 - NOTE that this may require shortening of tie rod in order to get toe in spec).
The cost is $350 shipped to your door. You must send me a set of CLEAN, BARE strut housings. I am no longer providing a core exchange program. Note that this includes only modified strut housings, no additional coilover parts or POR15 coating as pictured.
I have only performed these modifications on UrS strut housings, however the same procedures could easily be done on housings for other chassis.
Re: Custom front strut housings for UrS4/UrS6 coilovers...
Postby loxxrider » Wed Mar 20, 2013 9:16 pm
Nice! This is much needed in the community in my opinion :)
Postby amd is the best » Wed Mar 20, 2013 9:18 pm
This job is a decent PIA and I think $350 is VERY worth the price. I would have had you do mine if this way available when I did them. T44 uprights are almost identical for anyone wondering.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
Postby ringbearer » Wed Mar 20, 2013 10:10 pm
I've got a set done by Ed and they look great!
Postby Kuma » Wed Apr 10, 2013 11:21 am
how much more or less work would be involved for a CQ front and rear?
same price?
if so i may go ahead and search for some spare struts and such.
Kuma
Postby EDIGREG » Thu Apr 11, 2013 12:32 pm
Kuma wrote:how much more or less work would be involved for a CQ front and rear?
same price?
Well, it's more work in that, for the UrS, only the fronts need modified. Otherwise it is the same. Shoot me a PM and we can work something out.
Postby WOMBAT » Thu Apr 11, 2013 2:57 pm
This is awesome :) depending on my laziness I might take you up on this!
Postby versacehobo » Tue Jul 30, 2013 4:02 am
Sent you a PM mate, really need to sort something out ASAP as my car is pretty much rendered useless currently :police:
versacehobo
Postby DannyboyUpstate » Sun Jun 15, 2014 8:37 pm
Are you still doing these?
DannyboyUpstate
Postby EDIGREG » Mon Jun 16, 2014 7:18 am
Yes, still doing them. Send me a PM or email if you are interested
Postby DannyboyUpstate » Tue Jun 24, 2014 7:56 pm
EDIGREG wrote:Yes, still doing them. Send me a PM or email if you are interested
Hey Ed- I sent you an email based on some address you posted on quattroworld about a week ago. Not sure if it's the right address or it went into your spam folder or whatt? For some reason it wont let me PM you here either.
DannyboyUpstate
Postby EDIGREG » Wed Jun 25, 2014 3:24 pm
YGM - what do you mean the site won't let you send me a PM though?
Postby DannyboyUpstate » Wed Jun 25, 2014 7:16 pm
Replied to mail. I don't know why, but it keeps telling me that the user no longer exists? I have successfully PM'd with other people on this site. Strange.
DannyboyUpstate
Postby DannyboyUpstate » Wed Jun 25, 2014 7:17 pm
DannyboyUpstate
Postby themagellan » Mon Jul 07, 2014 4:13 pm
Danny - your problem is that you are entering a Subject into the username area (Look a little bit down more), I just did the same thing and came back here to post it :P
Postby DannyboyUpstate » Mon Jul 07, 2014 9:00 pm
Thanks for the tip Mag. I'll check that out next time I try to PM someone.
DannyboyUpstate
Postby blackdude716 » Sun Oct 05, 2014 6:16 pm
Will you still be offering these over the winter? Im looking to grab a set before Christmas! Also how much of a drop can I achieve with these on a 93 urs4?
blackdude716
Postby EDIGREG » Mon Oct 06, 2014 11:41 am
blackdude716 wrote:Will you still be offering these over the winter? Im looking to grab a set before Christmas! Also how much of a drop can I achieve with these on a 93 urs4?
Yes, send me a pm
You will be able to go as low as you want - the physical limitation is the control arms and the bottom of the car. And of course shock travel.
Postby blackghost » Wed Jan 23, 2019 9:11 am
I know I am raising the dead here. I figure posting this might help others aside from having a private side convo.
My question for Ed and anyone else to chime in: Would this work to raise the car another 2 inches over stock? I want to lift my avant! With your experience modifying the struts, are there any issues/limitations aside from getting a longer travel insert (bilstein HD)? I might start a separate post, but why not go straight to the source..
THANKS!
blackghost
Postby pilihp2 » Wed Jan 23, 2019 2:47 pm
Running any kind of aftermarket camber plates won't help with lifting the car. You'll need a spacer of sorts to space where the spring mounts away from the plate. These will actually help with lowering.
91 v8 5spd - I guess I'm a masochist
05 S4 - "Daily"
16 KTM 690 Duke - 2 wheeled hooliganism
Return to Member Products
