Ok yeah I looked at it again. So here’s how much space I have to work with . I should be able to do a 90 degree ell downward and towards the middle id I want to do a center inlet IC , and if not , I will do a custom end tank I guess . If there is an OTS intercooler I can get I will do that .
Hopefully I can fit one in there , and the closest spot (crank pulley) there is only 5.5” of space
So now that the engine is sitting in the car- not for good, but anyway I can finish the exhaust header, so I have three things left to do . Weld the head flange on without warping it , weld the turbo inlet flange, and finish the wastegate .
I took the strongback and drilled the proper holes in it so I can get bolts and fasten it down right before I do this welding , the flange is only barely tacked in right now .
The strongback is thicc as hell and milled perfectly flat , so I’m hoping if I bolt this down tight and don’t weld too much in any one area , let it cool, repeat , it should be ok.
I then need to trim the collector and weld on the turbo inlet V-band , again , without warping it . Not my specialty ...
Then after than , I can get the WG feed pipe and flange on. I was planning on using 1.5” sch 10 for that and putting it at a slight angle.
