Ok bad news and bad news .
Bad news #1 : I haven’t had any time to work on anything .
Bad news #2: The stupid cork CV axle gaskets don’t fit . They are about 88 or 90mm m too small .
So, after looking into it again using 7Zap I'm not finding any gasket but I'm seeing a tube of sealant that looks like it runs about 100$ from Audi. So Im guessing ill either be cutting cork gaskets out with an exacto knife or using some sealant.
Bad news #3 : The brake calipers don’t fit over the rotors. This is the largest MC4 mechanical parking brake caliper I can find. So I want to make it work .
Rotor dia measures 22mm.
Distance between the pads is about 20.6mm
The pads are super thin, 6.9 mm each.
So I guess I have 3 options at least,
1- Sand the pads down somehow 1mm each
2-turn 2mm off the rotors
3- fixture this in the mill and mill this circled area where the back of the pad goes.
I may have an idea , when I get a day off I’ll look at it
