jbrentd's 2nd Chance CQ - 3B Swap/Susp Overhaul In Progress
Re: jbrentd's 2nd Chance CQ - 3B Swap/Susp Overhaul In Progr
Postby PRY4SNO » Mon Sep 07, 2020 7:42 pm
I'd absolutely clean it using a wire wheel before using a flapper disc. Might be worth it to get one for a drill too, lower power and adjustable speeds which might not disturb the metal any more than necessary.
Postby jbrentd » Mon Sep 07, 2020 7:54 pm
PRY4SNO wrote:I'd absolutely clean it using a wire wheel before using a flapper disc. Might be worth it to get one for a drill too, lower power and adjustable speeds which might not disturb the metal any more than necessary.
Thanks for the tip. I do have a couple wire wheels for my drill.
jbrentd
Postby DE80q » Mon Sep 07, 2020 8:54 pm
Absolutely use one on a drill. You can run it full tilt in a drill and it won't spin fast enough to really do anu harm. I just had this conversation with a good friend this morning haha.
1991 Audi 80 quattro (10vt project)
Postby jbrentd » Mon Sep 07, 2020 9:47 pm
Thanks to you both. This is new to me, so you won’t insult me at all by offering even the most basic of tips.
Considering that I would be applying a rust correction product like POR15, am I looking to just knock down the high spots?
jbrentd
Postby PRY4SNO » Tue Sep 08, 2020 12:23 pm
I'd say mostly just looking to remove anything that's going to flake off on its own. Try to keep as much metal as possible and find the thin spots so you can repair appropriately. The rust converter will help rescue metal to some extent but want to make sure you find all the thin spots first.
Postby jbrentd » Sat Sep 12, 2020 6:53 pm
Spent some time trying to clear out the wiring harnesses that run along the door sills.
This is what scares me the most about all this mess. This is the bundle going to the driver’s seat. It’s a wonder it all worked.
jbrentd
Postby PRY4SNO » Sun Sep 13, 2020 5:05 pm
Ruh-roh.
This is the sort of easter egg that leads to scope creep.
Postby jbrentd » Tue Sep 15, 2020 10:34 pm
PRY4SNO wrote:Ruh-roh.
Yes, but it feels I’m already way deep into the scope creep phase at this point, what with the suspension work, HVAC swap, etc. [FACE WITH TEARS OF JOY] I have wrapped all of the bundles in new cloth tap and I’m crossing my fingers that I have not disturbed them too much. I have not seen any sections where the wire insulation has flaked off.
Last weekend I managed to scrape all of the original sound proofing material off. Driver’s side rear floor had more rust than I thought it would, but not nearly as bad as the front. I also was able to remove the sticky residue left behind in the areas where the metal was in good shape, but failed to snap a pic afterwards.
Next up is to find all the holes and thin spots and start prepping for POR15. I plan to use a combo of mesh and several coats of POR15 on those areas. I think I am going to coat the entire area under the carpets in it. It’ll be black, but it’s all covered up by carpet and trim.
jbrentd
Postby DE80q » Tue Sep 15, 2020 11:32 pm
Nice work, what is your plan for sound deadening?
Postby jbrentd » Wed Sep 16, 2020 11:47 am
DE80q wrote:Nice work, what is your plan for sound deadening?
I was thinking of using Kilmat, but am open to suggestions. The 80 mil stuff comes in a 36 sf pack and 50 mil comes in a 50 sf pack. Both are ~$60. Not sure what thickness is needed.
jbrentd
Postby PRY4SNO » Thu Sep 17, 2020 11:32 am
I'm very interested in what the group has to say about viable Dynamat alternatives.
Postby jbrentd » Thu Sep 17, 2020 2:59 pm
PRY4SNO wrote:I'm very interested in what the group has to say about viable Dynamat alternatives.
The KilMat stuff gets good reviews and is cheaper than Dynamat. Have seen a few threads here and on MG of people using it as well.
jbrentd
Postby jbrentd » Sat Sep 19, 2020 5:52 pm
Ran across this product too. Tempted to use just this, rather than both sound deadening and jute. I would use adhesive and double up on the firewall and areas under foot. Thoughts?
Car Insulation - 4' x 10' Roll (40 Sqft) Sound Deadener & Heat Barrier Mat - Automotive Lightweight Thermal Insulation
https://www.amazon.com/dp/B016QUS1YE/re ... zFbNQE3DEM
jbrentd
Postby themagellan » Sat Sep 19, 2020 10:30 pm
Used this on a 65’ bug And really made it livable, didn’t get it close to anything hot but was easy to apply and affordable!
Previous
Return to Projects
Who is online
Users browsing this forum: Google [Bot] and 21 guests
