jbrentd's 2nd Chance CQ - 3B Swap/Susp Overhaul In Progress
Re: jbrentd's 2nd Chance CQ - 3B Swap/Susp Overhaul In Progr
Postby PRY4SNO » Sat May 30, 2020 10:49 pm
For the cost of a zip tie, that's like found money.
Thanks for sharing that info.
Postby jbrentd » Tue Jun 23, 2020 2:00 pm
Not much progress, but a little. All of the suspension and brakes are off the car, except the rear top mounts (I’ll get to those soon). The Summer heat is making me lazy. While I was looking for a set of e brake cables, I went ahead and ordered a full set of reman’d brake calipers, rather than rebuilding mine.
I’ve been working on removing the CA and subframe bushings. What a PITA! I’m only half way done and every one of them has put up a fight. Still have the rears to go and they look the worst (at least the CAs do).
I bought a ball joint press kit with the hopes it would make things easier, but have had to resort to heat, penetrating oil, hole saws, hacksaws, BFH’s, and chisels. I’ll be glad when this work is behind me so I can put some Verkline bling in.
jbrentd
Postby ert » Wed Jun 24, 2020 6:47 am
I usually run a drill bit between the outer metal sleeve and the bushing rubber. It runs 360 degrees between the sleeve and rubber portion and cuts them apart. Then just knock out the old bushing and cut the outer sleeve with a saw, just like you have done. I've found this to be the easiest and least messy way to remove old bushings.
ert
Postby Peters » Tue Jun 30, 2020 7:27 am
A hole saw makes quick work of the rubber bushing, I then use a hacksaw to get a notch started on the sleeve and finish with an air hammer to collapse the sleeve on itself
Peters
Postby jbrentd » Tue Jun 30, 2020 10:29 am
Peters wrote:A hole saw makes quick work of the rubber bushing, I then use a hacksaw to get a notch started on the sleeve and finish with an air hammer to collapse the sleeve on itself
Thanks for the tips. I can't seem to find my air chisel...I know I had one at some point. Might need to pick another one up.
jbrentd
Previous
Return to Projects
Who is online
Users browsing this forum: No registered users and 28 guests
